Hard disk not found. message from vaio recovery disks and xp os disk,tried both. should be noted the hdd's are connected to a card which combines their connectivity into one output to the mobo.
Pushkar kumra after inspecting the ram your advice I discovered the sticks were not properly seated
  • 42 Answers
Either the drive has started failing or cable connection is lose. Try fixing the both and see (replacing the hard drive to another computer) and see if the same happens again.
Thanks and good luck!!
Posted on Apr 13, 2015
    Habit-Forming:
    New Friend:
  • 54 Answers
Dear
restart the PC press F11,
choose your booting device,
rgd
Jagjit Mishra,
amit.mishra.lenovoservice@gmail.com
Posted on Apr 06, 2015
  • 70 Answers
Have u check your hard drive jumper settings?
ibleedblue18
  • 50 Answers
SOURCE: Sony Vaio PCG-TR3A, Blue Screen states cannot find operating syst
There should be a factory image on the HD when you try restarting it. Hold down the F8 key or F10 key while its rebooting this should start the recovery process you shouldnt need a windows disk.
Posted on Dec 04, 2008
  • 10 Answers
SOURCE: get error message "operating system not found"
Run diagnostics on the harddrive. if possible reseat the Hard drive, i.e take it out and put it back again. and then try installing the OS. remember you have to boot from the laptop to install OS. Hope you are doing it correctly
Posted on Apr 09, 2009
  • 48 Answers
SOURCE: ethernet port on laptob gateway not working
http://support.gateway.com/support/drivers/search.asp?param=MX6447&st=kw
From a computer that has internet access, download the appropriate ethernet driver for your network card from the link above. As for the recovery disk, you'll have to contact Gateway for a replacement disk.
Posted on Apr 14, 2009
MNfisherman
  • 11896 Answers
SOURCE: NO HDD RECOVERY AREA !
first boot pc, then right before windows would start, press either F2 or F8,, I think it's F2, this will bring you to bios settings, look for bootup device options, Set cd-rom as first bootup device, then Hard drive as second device, Then save settings, insert recover cd, then restart pc, it will immediately boot up your recover cd or windows disc
Posted on Oct 06, 2009
jadiazq
  • 2878 Answers
SOURCE: sony vaio error 333
Try deleting partition(s) and re-creating. This problem has been around for a while. It could be the hard drive, but most say it's the disc.
Posted on Sep 26, 2012
Need to get winVista Home from Sony Vaio VGN-NS230E recovery disks to new 1TB HDD
Could be a recovery partition. Could be hard drive software partition. Could be junk.
Leave it and have an extra 10GB drive later. Or, delete it and take advantage of the space. If the recovery recreates it you will know where it came from.
On a side note, I suggest partitioning the 1TB drive. Make a OS partition, and possible 2 other partitions. It will help with defrag and keep your important files out of the OS side in case another recovery is required.
Oct 25, 2012 | Sony VAIO VGN-NR498E/S Notebook PC
I HAVE ACER TRAVELLMATE 6231.NOW IN THIS LAPTOP OS IS CORRUPTED,SO I WANT TO REINSTALL OS BUT WHEN I INSERT BOOTABLE CD IT SHOW ME "SETUP DID NOT FIND ANT HARD DISK DRIVES INSTALLED IN YOUR...
You are trying to install windows xp? The normal windows xp cd will not have drivers for newer laptops. You will get this error message.
What you need to do is to try using acer recovery instead.
Acer machines should have a build in recovery, hold down ALT and presson F10 repeatedly when you power on the machine, keep pressing every 2seconds until acer recovery comes up, if it doesn't come up then yourmachine probably doesn't have that option, the laptops mostly have it.
If you are unable to do the above then you may be able to order recovery discs from ACER --https://secure.tx.acer.com/RCDB/Main.aspx?brand=Acer
Sep 20, 2010 | Acer Aspire One PC Notebook
Vaio operating system not found.
first check that your hdd is detecting by your laptop.
i think you have removed mbr master boot record from your hard driver the soution is to create master boot record in your harddrive by using mbr commands.
May 06, 2010 | Sony VAIO VGC-LV110N PC Notebook
Vgn-nr185e (sony vaio) read error.. alt+ctlr+del to restart
what are you using to reformat the hdd? if you havent formatted the hdd using any retail version of od disc, youmay try to access the vaio recovery partition.. that is when you restart the computer, then press f10 key repeatedly for 5-7secs. it will load vaio recovery center. then from there, select restore c: drive. follow on-screen instruction and it will format the hdd. process may take for 45mins up to an hour
Mar 18, 2010 | Sony VAIO VGN-NR180EW Notebook
Evesham Axis RD A-List failed HD - can't boot from CD
Sounds like the hdd is failing. Do you have a restore disk or OS disk? Or was there a restore partition on the failing hdd? Either way, it looks like your going to need a new hdd and at least a restore or OS disk. Not real familiar with the Evesham Axis.
Dec 30, 2009 | Computers & Internet
Recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
May 09, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
HARD DISK NOT FOUND MESSAGE ON SCREEN
There might be few reasons for this.
The worst is that your Motherboard/HDD is broken, but I am almost sure that this is NOT the case. Motherboards and HDDs do not burn just like that !
The good thing is that you can 'see' your HDD in BIOS, which means it is not dead!
There can also be a wrong BIOS settings for the HDD controller. Check BIOS settings for your HDD-SATA controller. Somehow maybe your BIOS lost/changed HDD settings.
The problem is that I am not sure you can check your HDD on another computer. If you can do that, then it is the best chance to determine if something is wrong with your HDD, Also there (on another computer) you can more easy use some HDD test and repair software. Also, that way you can easy make backup of your important files.
Bott from WINXP BOOT disk and try recovery console (chkdsk/p at command prompt)
Try to download Hiren's Boot CD(http://www.hiren.info/pages/bootcd).
Regards
Apr 20, 2009 | Computers & Internet
Get error message "operating system not found"
Apr 09, 2009 | Sony VAIO VGN-FJ270/B Notebook
Can't find OS
Even if you set it to slave, what has happened is the drive motor is burned out. Lets face it, your HDD is dead and there is no hope of recovery unless you take it to a data recovery shop, and that is $$$$.
The No OS message is the worst message you could possibly see and that is a direct indication that your HDD is dead in the water.
Just go get another HDD or go buy XP to replace ME on that other HDD you have.
Realistically there is nothing you did or didn't do to cause a harddrive failure. It is just the way of the world nothing lasts forever...
Sep 04, 2008 | Maxtor DiamondMax Plus 6800 (91366U4) 13.6...
Operating system not found, hard disk not found message showing in IBMT20
On my ThinkPad Notebook Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Dec 26, 2007 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
