SOURCE: mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
SOURCE: Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
SOURCE: oil change and spark plug
Please rate this solution as a " FixYa ". Thanks!
SOURCE: My 1999 gilera runner 50cc cut out on me,now it won't start
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it and clean it. With the gas valve turned off, does gas still get past the valve? If it does, then you need to replace the valve. Re-mount the bowl, ( not all bikes have a water trap bowl ). Always turn the gas off when not riding the bike. If the valve will not fully shut off the gas then a leak-down condition can occur and cause gas to get to the exhaust pipe.
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
SOURCE: my mercedes e300 (1989) starts and runs ok but then cuts out.
I had a similar problem with my 1986 300e , which got progressively worse until the car was no longer driveable, I changed out the fuel pump relay and the problem went away.
