Question about Alpine In-dash Unit Car Cd Audio Stereo Receiver Cde-103bt W/ Bluetooth No Knob
Factory default band width settings - Alpine In-dash Unit Car Cd Audio Stereo Receiver Cde-103bt W/ Bluetooth No Knob
Firmware required
If the the printer will only print 80 column rather than 136, and you know your print job is 136 columns, firstly check the menu settings to ensure the printer is not set to 8inch width. If the printer is set to 8inch width you will not be able to print more than 80 columns.
If you are printing from a Window application you will need to ensure you have the correct paper size (ie 13.6 inch wide) selected in the Application AND the printer driver.
If you are sure the print data is wider than 80 column and the printer menu is set to 136 column and you still are not able to print wider than 80 column it may be necessary to reset the device back to factory settings. (Before doing this I would recommend printing the current settings or make a note of the current settings as you will need to set the device back up again)
To reset the device to factory default;
  1. Start with the printer powered off
  2. Hold down the four grey buttons under the LCD
  3. Keep the four grey buttons held down and power the printer ON
  4. Keep the four grey buttons held down until you see 'Loading Default' of the printer has finished initializing.
Once you have done this you should be able to print 136 column prints.
If you can not I would suspect the data is not greater than 80 columns in width and you would need to check the computer system set up.
Apr 24, 2014 | Tally T2250 Matrix Printer
Nike fuelband didnt reset
This same thing just happened to me. I just reset the band.
Here are the instruction from the Nike help site:
Resetting Nike+ FuelBand to factory settingsIf you want to reset all the FuelBand settings back to the original factory defaults, connect your Nike+ FuelBand to your computer to open Nike+ Connect and select Factory Reset from the Settings window (see image below).
This will clear all user settings and any unsynced activity from your FuelBand. However, the activity you've already uploaded to nikeplus.com will remain intact and attached to your Nike+ profile.
Most FuelBand users shouldn't ever need to take this step. It's useful for advanced troubleshooting. It's also useful for clearing your user settings if you want to transfer your FuelBand to another user or associate it with a different Nike+ account going forward.
http://nikeplus.nike.com/plus/support#answers/detail/a_id/35550/p/3169,3180
Jan 11, 2013 | Nike Fuel Band Medium
Printer t2280+ displays paper width error after printind only one line and stop . even on selftest without connecting to the system
Hello
When using the Show method of Data Report to preview the report, the page orientation defaults to the default printer settings on the local computer. Therefore, if the orientation of the default printer settings is set to Portrait of standard Letter paper and your report width is more than 8.5 inches wide, the following error occurs:
1. Make sure that there is no extra white space in the report. If there is any extra white space in the report, close up that section so that the ruler falls within the width of your default printer.
2. Set your Left Margin and Right Margin to 0.
3. Check your printer setting to ensure that your default printer is set up correctly. If the report is landscape (that is, greater than 8.5 inches) the default printer should be set accordingly.
Jun 29, 2011 | Office Equipment & Supplies
I forgot my password and want to know my password
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Hope this helps don't forget to vote
Feb 27, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
How can i get my password 4 my network
or
if there a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Dec 07, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
I have full signal but my phone is only allowing emergency calls how can i fix this?
Most Samsung Mobile show signal tower even if there's no network accessible. I am not very sure about this model, but you can find out, install an expired sim card and check if the network tower is showing or not, or you can just power it on without sim card and check the status of the network tower.
If you suspect the Phone, then first try your sim card on another handset/mobile and make a call using the sim card. In case it's working, then the problem is with your phone, could be settings or could be hardware or software related issue.
Reset your phone settings to it's factory default by going to the "Restore Factory" or "Master Reset" and make the changes. Try searching the Network Manually and do check the network settings very carefully. With many Samsung mobiles, there's an option that allows us to select the Network Band, so verify that there's no band selection problem. You can make the changes after you go to the Network Settings. The simplest method is to Reset the Settings to it's Factory Default.
Good luck.
Thanks for using FixYa.
Aug 22, 2010 | Samsung U900 Soul Cellular Phone
I want to know how to video call on a Lg GD900
HI
Since your phone supports 3G,
For making video call you need a 3g network
which offer higher band width.
If you have a 3g enabled SIM,
then
you will be able to video call in 3g network By default.
for more details on the 3g service of your network,
just call the service provider and they will give the settings for the 3g network
and guide you.
Hope this will help you.
Mar 18, 2010 | Cell Phones
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Tension factory settings for Baby Lock serger Model BL400
The factory settings are 4, 4, 4, 4, and width at M. Hope this helps.
Mar 03, 2008 | Baby Lock Eclipse Serger
Two or more black bands appear
Try resetting all parameters to factory settings. Do it once and then set your personal settings. Then, reset to factory defaults again.
Jan 23, 2008 | Toshiba TDP-S8 Multimedia Projector
Alpine In-dash Unit Car Cd Audio Stereo Receiver Cde-103bt W/ Bluetooth No Knob Logo
Top Alpine Audio Players & Recorders Experts
 Grubhead
Grubhead
SHARCNET-USA
SHARCNET-USA
Are you an Alpine Audio Player and Recorder Expert? Answer questions, earn points and help others
