50 INCHAdjust picture size to fit screen - Televison & Video
  • Televison & ... Master
  • 9,742 Answers
Picture size depends on how the program is broadcast to the TV. You can use shrink, letterbox on some tv's to expand a picture but the aspect ratio will be wrong. There is no adjustments if a program is broadcast in standard definition and viewed on a HI definition TV.
Posted on Apr 03, 2015
How to fix horizontal lines on LG TV
Not sure if this is recent but in settings adjust picture size to fit. Top to bottom side to side.
sounds like you are seeing what are called retrace lines
Sep 30, 2016 | LG 50" 5700 Series LED HDTV - 50LN5700
Image size fit screen
Try pressing your "zoom" button on the remote. If that doesn't work, try pressing the video button to see if that changes your picture as well. One or the other should solve your problem.
Jul 15, 2014 | Insignia Televison & Video
Fitting picture to screen size
on the remote control you would see a key that it say P.size , if dont have this key go to the menu of your tv not the cable box menu , and go to picture a look for something that it say picture options under that you would find the screen size and you can get the right screen size
Feb 03, 2012 | Televison & Video
Picture size is not right
You can go into your picture settings and change your aspect ratio. This should fit the picture to your screen. Sometimes depending on the model this can be done with the remote as a separate button there. Other than that it will be in your menu settings. You'll be looking for 16:9 16:10 4:3 etc etc for the sizes.
Jun 07, 2011 | Samsung 50 in. Plasma TV
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
My picture does not fit the screen. It is as if it is zoomed in too tight. Scores and stats on sports are not visible on screen, etc.
This can usually be solved using the picture size function. Most stations that broadcast in HD now will have part of the screen cut off. On samsungs you can switch between the picture size being 'Normal' and '16:9'. Try both to see what works better.
Jan 23, 2011 | Samsung HPT5054 50 in. HD-Ready Plasma...
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Picture size
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Jan 05, 2008 | Toshiba 50H82 50" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
