Question about Kitchen Ranges
My digital clock works but it no longer stays on how do I fix?
I can't get the projection light to stay on?
I've had this clock for a year now. The projection light will no ...
www.amazon.com/clock-projection-light.../1?_... Amazon.com, Inc.Sep 13, 2013 - The projection light will no longer stay permanently on - it used to. ... if it during the day you can't see the projection because of ambient light. Questions And Answers: does the projection light stay on 24 ...
Jan 7, 2014
Amazon.com: Questions and Answers: Oregon Scientific RM313PNA ...
Jul 19, 2013
More results from www.amazon.com
Oct 19, 2015 | La Crosse Lacrosse WT-5120U-BP Projection...
Why won't the clock stay lit? Shows the correct time, but only stays on for a few seconds.
Some clocks work that way. I guess they're just saving power.
Hope this helps.
Feb 24, 2015 | Ovens
The cruise control won't work -air bag light stays on and just put in a new clock spring to fix this but that did not work? Any ideas?
check fuses and relay. if not.....double check that clock spring.
sorry thats not much help.
Jan 27, 2013 | 2002 Lincoln LS
Clock display won't stay lit
Same thing happened to our Kenmore range and I found a solution on the web about fixing this problem on a fridgedaire range. It was to hold down the clock button for an extended time ~15 sec. It worked for our kenmore and hopefully for yours too.
Feb 10, 2010 | Kenmore Ovens
TV reception band no longer works
all analogue signals going out means EVERY analogue signal is gone in the TV band. these are now apparently assigned to emergency services in some states.
Jun 14, 2009 | Audio Players & Recorders
Jenn-Air Electric range clock display
The problem is likely bad capacitors on the clock module. I had the same problem on a similar oven and fixed it by replacing the capacitors on the clock module. Find someone who is good with electronics to help you. The parts will be a few dollars at most. See this link for more info: http://www.badcaps.net/forum/showthread.php?t=7902
Oct 06, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Clock working, but not displaying time
They say to hold the button for 14 seconds or til it beeps, for it to stay on.
Jun 24, 2008 | Frigidaire FED367 Electric Kitchen Range
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
