Question about Toys
F-163 Top Speed Helicopter will not take flight
This Helicopter lifted one time and then after that will not fly. I have charged the battery fully and tighten down the screws and still will not take flight. Any suggestions out there. Thank You
    Novelist:
  • 166 Answers
Likely defective unit and needs a warrantee replacement.
Posted on Apr 03, 2015
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
I have a skyforce gravity r/c helicopeter trying to fix for my son.When it is plugged in the charger, it just blinks green light. Have it over night, and it is still just blinking green. Have lost remote....
It means that the charged battery is full. Some chargers have a steady glow, others have a flashing light to show that the battery is charged. When you run the helicopter, is the battery fully charged, does the helicopter blades spin flat out? If so, the battery is charged and the flashing light indicates the battery is charged. If the battery isn't charged or the blades don't spin enough to lift the helicopter, or fly for some time, then the battery isn't charged and the charger may be faulty. Take it to a hobby shop to see where the problem lies, the charger and its blinking light, or the battery.
Dec 28, 2014 | Toys
Will not fly lift . Seem to run well but will not lift off the ground
The batteries on the Helicopter need to be fully charged to take off.
And important: to recharge the helicopter fully it needs really good base unit batteries.
I find all this a waste so - I used a wall power supply to supply suitable power to the charging bases of these helicopters give more consistant results than using batteries.. Just make sure you are using a 9V DC wall transformer (6 1.5v batteries = 9v) and that the polarity is correct.
manual is here
http://www.brookstone.com/webassets/pdf/651307p_manual.pdf
Dec 18, 2013 | Brookstone uControl Cloud Force RC...
Sky Force 3.5 Channel Infrared Gyroscopic Helicopter will not fly, it will not lift off the ground. Does anyone have any advice
Mine does the same exact thing it just will not lift off the ground, nor will it charge. I have tried changing the wings, and batteries but it is still a no go... But i am pretty sure it is because the motor will is not getting enough RPM's or torque. any help is much appreciated
Thanks, Michael
Jan 02, 2012 | SYMA Toys industrial 173 Whitecap Toys
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
How will be i identify it is fully charged battery i charged for 45 minites.But the battery will not be fully charged. please send me the solution for this problems
If using usb charger use usb port on back of desktop, not data port in front, also most laptops do not have fully powered usb ports due to battery consumption. The wall charger, or a usb charger plugged into a usb/ac adapter (like included with ipods and kindles or sold seperately) is your best bet for reliable charge.
Charging unit should have a light on it.
When charger is plugged into power source and not helicopter, the light will show you {#1} what it looks like when battery is fully charged. Typically this is steady on, and usually red. (sometimes green) When you connect helicopter to charger, the light will change (usually goes dark) to signify it is charging {#2}. When light comes on fully (or completely returns to #1) then charging is done. (Note: charging using a laptop usb or a front side data port usb can take several hours.) Watch the light on charging unit when you unplug helicopter, if it gets brighter, helicopter is not charged, plug it back in. Make sure to let battery cool for 10 minutes after every charge and 10 minutes after every flight, and never run battery all the way down. As soon as you can't maintain altitude, land and power off. Fully draining a Li/Po battery weakens it's ability to hold a charge and can ruin it.
If all else fails, replacement batteries are available from Amazon and many others, they are cheap (around 5$) and very easy to install with no soldering and just a small screwdriver.
Hope this helps
r
Dec 31, 2010 | SYMA Toys industrial Syma S032 Ready to...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
I bought on of those falcon-x helicopters for my son and just wanted to know how to charge the battery as efficiently as possible. The helicopter needs to be off correct? And how long should it charge for...
The instructions say the helicopter is ready to fly when the led shows red. I found some info online that says to charge the helo for 35 minutes. I've been letting it go 45 mnutes, and have been getting abou6 6 minute flight times. Unfortunately, my helo will no longer fly forward or backward. Does anyone know how to adjust the control for the tail rotor?
Dec 25, 2010 | Toys
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
Toys Logo
78 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
