Question about JVC KW-XR611 Double DIN iPod Ready/USB/iPod/CD/MP3 Radio Tuner
Not responding even after reset, it stays on FM 87.5, buttons dont work
  • Antonio Proti
    Antonio Proti Apr 05, 2015
    When i turn the radio on, it doesnt respond to any of my comands it just stay on station fm 87.5, i tried to reset the radio but noting happend it still dosnt respond, the radio chages colors and plays music only if someone passes whit radio trasnmiter on frekvency 87.5
Reset Water Filter Button; Stays Red after changing filter on Frigidaire Refrigerator/SideBySide LGUS2642L
Thank you for your inquiry, John Sodt!
From what you have described your Frigidaire refrigerator's filter display is not changing back to green after the filter has been changed. This could be a miscommunication within the control panel and to clear out any miscommunications I would suggest performing a reset on your refrigerator. The best way to reset your refrigerator is to unplug the power cord for roughly ten minutes. If that does not help your issue you may want to speak with a professional technician. Good luck. -Matt
Feb 11, 2015 | Frigidaire Refrigerators
Dear sir : i have a car audio player and i want to change the fm band to the second one from 87 to 108 also i dont know what its kind and if u have a manual for it ill be very thankful urs m ....
The 87-108 band is FM. The "second one" would be AM.
Press the AM FM button to toggle between them.
Can't help on the manual. If you had a model number you could possibly run it by these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usersmanualguide.com
Mar 12, 2011 | Audio Players & Recorders
Acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to...
acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to factory defaults. please help
Dec 24, 2009 | Acer PD100 Multimedia Projector
Won't work after replacing batteries
sounds like the batteries might be in backwards. Please remove the batteries and then put them back in insuring that they go in correctly.
Oct 30, 2009 | Computers & Internet
Oil light stays on although level is up.
Either low oil pressure, or a leaking switch. If your switch is not leaking, you most likely have an oil pump problem, or a worn out motor.
Jul 06, 2009 | 1987 Pontiac Grand Am
Sangean ATS-803A - no audio
If its not a micro-p glitch, sounds like the radio was subject to a spike or surge wile plugged into the AC adapter. If the "power" light stays on all the time, thats what happened. Believe me, I was Sangean America's tech from 1990-1995.
Rob
The fix is to replace a transistor, or fet in the main pwr supply. (Close to where the adaptor plugs in.)
I wish I could give more details, but its been 14 long, long years.
Jun 03, 2009 | Sangean ATS 808A AM/FM/SW Radio
Getting Out Of F.M. Mode
use the button that looks like a house on the front of the player
Aug 03, 2008 | SanDisk Sansa Clip MP3 Player
JVC KW-XR611 Double DIN iPod Ready/USB/iPod/CD/MP3 Radio Tuner Logo
53 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
