Question about Garden
How to set cut level - Garden
  • 3,519 Answers
Hi Kyle:
If this is a push mower, The cut level is just about always set by adjusting the height of the wheels. There are usually little spring loaded levers that let you move the wheels up or dow.
SAFETY FIRST> NEVER try to adjust these with the engine running.
Posted on Apr 03, 2015
My Dyson dc44 multi floor is cutting out it started cutting out when I was using it on max setting but now is cutting out on normal setting.
It sounds like a battery level issue, as they automatically cut off when running flat. Try leaving the battery on charge for an extended amount of time (a few days, perhaps) and see if it comes good, otherwise you may need to replace the battery.
Aug 02, 2017 | Dyson Vacuums
Lawnmower wont cut short enough on lowest level
then you need to change the settings on the wheels , we can not do it for you .
May 15, 2016 | Garden
Set dial and water overflows, doesn't stop sending water in tub, No spin cycle
The water level sensor is faulty and so it does not switch even with water level coming to the set level. Unless the water level switch is triggered the water inflow will not stop because the inlet valve will not cut off.Remove the water level sensor and check if the diaphragm is working , if not it must be replaced.
Mar 13, 2012 | Washing Machines
My iron temp cuts off and only stays at a low temp even thou it is at it highest settings regards Mike
It is possible that the BIMETTALIC cut off is OFF set and so the cut off happens vry early .
You might need to remove the unit and get access to see if this can be set to higher level- tighter- so that the bimetal takes more heat to cut off. This will provide you a higher heat.
You can calibrate using the highest/lowest settings.
Aug 08, 2011 | Philips GC 148 Iron
How do I control the tank water level? It doesn't automatically cut off and I have to use the water cut off valve.
you can go to any home improvment store get a fluidmaster fill valve about $8.00 and very simple to install.Comes with instructions to install and how to set water level cut off!!
Jun 12, 2011 | Caroma 270W-RF Reflection Round Front...
The dehumidifier cuts off when it is set on 70% as soon as the compressor cuts on. i can leave it on lo and it runs.
If you're setting the humidity level on 70 % , that means you want to leave the relative humidity in the house at 70%. That's why the dehumidifier is cutting off. Your house is already at 70% humidity or higher. If you want to remove humidity, set the level lower. If your trying to make it cooler in the house or remove a lot of moisture, set it a 35 to 45%.
Hope this helped solve your problem.
Apr 16, 2011 | Kenmore Dehumidifiers
Blade does not cut straigt. How do I adjust the
There shoul be a scale and a crank or screw used to adjust the blade angle on the front of the saw blade feed bushing. Make sure you set this to 90
Feb 26, 2010 | Dewalt & Variable Scroll Saw
CHT12 speaker cuts out randomly have to turn off and on to get sound
Here is something you can try.
On your source check the output level for your sub.
Try setting up at a higher level, if at 1 set it for 2 or 3
Then adjust the volume control on the sub down to mach the speaker volume level.
Nov 25, 2009 | Velodyne CHT-12 Subwoofer
Carbies willn't set float level,right floods,left sets to low
I don't know if its any help but I've fixed my Honda with similar problem. It turns out I reassembled the rich carbys air cut off valve incorrectly. Have you checked yours? I'm wondering if the cut off valves somehow affect the other parts of the carbys. Mine is running sweet now.
Apr 13, 2009 | 2001 kawasaki ER-5
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
