Question about Precor C954i Commercial Treadmill
My 954i treadmill will not increase the belt speed when the button is pressed . It will start at 1.0 and decrease when the down arrow is pressed until it stops. What do I need to try and Fix?
Only the up arrow button doesn't respond... so we can not increase the speed at all. All other buttons seem to work, including incline and decline arrow buttons.
  • 656 Answers
The micro switch is probably bad, the button (micro switch) needs to be replaced.
Posted on Apr 03, 2015
The speed will not decrease once the treadmill is started. The speed will increase when the button is selected but will not decrease when selected. Everything else still works except the (speed down)...
Most likely the directional PCA has popped out of its housing. There is a small circuit board underneath the quick start button that works the controls. They are notorious for coming loose. If board is still in the housing then then speed down sector of the board may be bad and it will need to be replaced
Aug 13, 2013 | Precor C954i Commercial Treadmill
Tip
HORIZON FITNESS TREADMILL ENGINEERING MODE AND RUNNING BELT ADJUSTMENT
Eng0 - Display and Button Check
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng0 appears in the display.
2. Press "Enter" to select Eng0.
3. Press "Start" button to verify all LED's
Eng1- Hardware Test
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng1 appears in the display.
2. Press "Enter" to select Eng1.
3. Press "Start" button to verify belt movement, sensor wire, and elevation function.
Eng2 - Auto Calibration
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng2 appears in the display.
For more check the following link . from the drop down menu select treadmills.
www.electro-medical.blogspot.com
on May 03, 2015 | Horizon Exercise & Fitness
My proform j8 speed up button does not increase speed
1) adjust the speed sensor, test it, clean it, and tight the connector very well. se the diagram
2) RUN The software calibration for troubleshooting, and fix it. go under the hood motor and follow the instruction or read your instr. manual very well how to enter in the s. calibration
God bless you
Nov 12, 2012 | Proform Exercise & Fitness
Treadmill Proform 450CX: unstable speed - no motor strengh
1) You must RUN the software calibration for diagnose, and troubleshooting, and fix it Inmediately.
God bless you
Jun 08, 2012 | Exercise & Fitness
Does anyone know how to change Livestrong LS10.0t treadmill from mph to kph?
Must enter the engineer mode. Turn the machine ON. Wait until you see the "Select user" screen.
1 - Press and hold the key to increase the incline and the key to decrease the speed for 3 to 5 seconds.
2 - Use the arrows to increase speed to get to Eng3 program (or the arrows next to the Enter button).
3 - Press "Enter"
4 - Then press the green start button until KM appears on the screen.
Apr 03, 2012 | Avanti Exercise & Fitness
My proform 590 treadmill has these problems ; belt slips when running or walking ,speed goes up and down does not stay constant and you can hear motor noise increasing and decreasing in motor what should...
simple(maybe). go to the rear of treadmill,get the allen wrench that came with it,run at med-slow speed and adjust the rear roller with allen wrench. 1 turn per side 2 or 3 time then walk on belt until wont slip. all the problem is belt tension. also. make sure if it need lubrication under board and belt(some are lubless others dont).
good luck to you.
Feb 08, 2011 | Treadmill Doctor Proform 590Qs Treadmill...
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Jun 11, 2010 | Tunturi T30 Programmable Treadmill
Treadmill Tunturi T 20 keeps inclining upward by itself
Testing Mode 1. Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then‘SPEED DOWN’ and hold buttons pressed simultaneously 2. LED scanning mode for verifying display functionality 3. Press ‘ENTER’ to scan DATA LINES to verify display functionality 4. Press ‘ENTER’ to scan SACN LINES to verify display functionality 5. Press ‘ENTER’ to scan LED’s to verify display functionality 6. After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) 7. Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ to decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
May 10, 2010 | Tunturi T20 Folding Programmable Treadmill
My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Feb 27, 2010 | Nordic Track NordicTrack Treadmill, A2550
Precor C954i Commercial Treadmill Logo
296 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
