Question about ViewSonic Computers & Internet
Why can't I control the brightness or contrast on my Viewsonic monitor?
I can access the control panel on the monitor and then access the 'contrast/brightness' folder within. As the directions say, I pressed 2 on the monitor face in order to select either the contrast or the brightness, and as either one are highlighted I am supposed to be able to adjust them using the up and down arrow keys on my monitor, but I do not have the ability to do so. When I have not selected either and are scrolling between the two they are colorful looking as if I may adjust them, but as I select one to adjust, the minus sign and the positive sign on either bar turns grey and I am not able to adjust anything. I have tried to find a way to adjust the monitor settings using my OS, but I'm not the greatest geek out there and couldn't find a way.
  • 615 Answers
Look to see if there is an "auto" setting, this would override the manual settings.
Posted on Apr 03, 2015
Testimonial: "There is an 'Auto Image Adjust' option, so I selected it and it didn't change any of the settings. I'm assuming it was already applied at some point."
The contrast/brightness panel comes on and won't leave the screen
check brightness button , if issue continues , might need button replacement
Feb 20, 2014 | ViewSonic VX2035WM LCD Monitor
The Bright/Contrast window, controlled from the monitor itself, keeps popping up. The select pane continues to switch between the Bright selection and the Contrast selection. When it finally stops...
Sounds like your monitor is going bad. You might get some more use out of it if you power it off for a couple hours and try again but my guess is this is a heat-related failure that is common on ViewSonic monitors.
Jun 30, 2017 | ViewSonic Vx2250wmled LCD Monitor
I am using a Viewsonic VX2235WM monitor for photo editing
Hi!
Its actually normal. That normally happens to some monitor models at the 6500K setting. Try a higher one.
I hope this helps.
Jubert
May 18, 2010 | ViewSonic VX2235wm LCD Monitor
Can not access PC Brightness or PC Contrast - only X Contrast
From p.29 of the manual
"Brightness, Contrast, Sharpness, Color, and Tint are only available for adjustments
if you select User in Picture Mode.
Press / on the remote control or VOL+/ VOL- on the control panel to adjust these settings."
Apr 12, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Viewsonic VA902b too bright. menu control greyed out
open the monitor draw the screw and there is a big black part called E.H.T.to which has preset to rotate it with screwdriver in on condition of monitor untill sufficient brightness will come
Mar 09, 2010 | Computers & Internet
Contrest & brightness menu always pops up and
there is a problem in micro controller chip in the monitor replace that biggest chip in the monitor problem will be solved
Feb 28, 2010 | ViewSonic VP920b 19" LCD Monitor
Brightness and contrast decreased automatically
check that you were not running any programs that you have allowed to automatically change settings, enter control panel and set settings to allow manual changes only!
Sep 04, 2009 | ViewSonic E70f (White) 17 in.CRT...
Always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Jul 28, 2009 | ViewSonic E70f 17" CRT Monitor
Viewsonic VG2021m contrast/brightness menu won't go away
I had same problem. The solution I got was to unplug power cord, and hold down each switch on monitor for 30 secs and switch on. IT WORKED! Hope it helps you too.,
Fred
Apr 12, 2009 | ViewSonic Graphic VG2021m LCD Monitor
Computers & Internet Logo
249 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
