Question about Akai LCT42Z6TA 42-inch 1080p LCD HDTV Refurbished
Why is there a constant hum on the speakers? - Akai LCT42Z6TA 42-inch 1080p LCD HDTV Refurbished
  • 615 Answers
The hum is coming from a poor input connection or possible a bad or electrically noisy power supply .
Posted on Apr 03, 2015
  • William Charnigo Apr 03, 2015
How do I stop the constant hum coming from my Azden SGM-1X Professional Microphone?
If the hum is from line pickup, it should be 60hz or 120hz. If you are connecting to a line powered device, you might want to try a direct or isolation box. There's a ton of them like these
Passive Direct Boxes
And see if orienting the mic at a different angle. Try turning off fluorescent lights. Isolate ie as much as possible.
Jan 01, 2015 | Azden SGM-1X Shotgun Microphone
I have the Klipsch Sub-10 Subwoofer, and it no longer plays music. Now it hums (vibrates constant) and corresponds (louder or softer) with volume control. Light is home but no one home situation. V
Does the subwoofer have the same hum when the input cables have been unplugged? Many input cables use very fine conductors, which often fail. A bad cable will often introduce a hum and prevent a signal from getting through. If the noise is still present without the input cable(s) connected, then repair options are limited. No schematics are available. There's a daughterboard that has been available, but its failure usually causes the system to die (short-circuit). The cost to repair the amplifier may be close to the cost to replace the entire sub.
Sep 14, 2014 | Klipsch Synergy Sub-10 Subwoofer Speaker
Woofer is humming
Usually a faulty cable or blown speaker will cause a humming. If it is a constant humming I would surmise a faulty cable. On the other hand, if the humming comes and goes I would guess a faulty speaker.
Dec 28, 2013 | Vizio 2.1 ch. Sound Bar with Wireless...
Omni S8 Subwoofer Constant Hum
4amom-s8n is the part number for the amp assembly
Apr 08, 2013 | Audio Players & Recorders
Annoying hum from speakers w/system off
The big electrolytic capacitor(s) in the power supply. The filter out the 50/60HZ hum in the mains, so you could be hearing the mains hum!
Jan 02, 2010 | Memorex MX4100 CD Shelf System
Constant hum from speakers
It sounds like you might have a grounding issue. Try connecting to the wall outlet with a ground prong lifting adapter. Not just the speakers but the source plugged into the speakers also. Good luck.
Oct 09, 2009 | Logitech Z-10 Computer Speakers
Constant hum when the computers are connected
Hums come from several sources. A light dimmer switch on the wall. Speakers too close to a monitor or other electrical device. Try turning off everything in the room or nearby rooms, one at a time while the hum is audible.
Apr 15, 2009 | Bose Companion II Computer Speakers
When i plug in my subwoofer it has a constant hum
Sounds like you have a bad connection somewhere. Make sure all of your connections are secure. If theres anything that is a little loose you'll get that hum. You might also try replacing your cable too. If it became pinched somewhere it could cause that problem
-Captain Jake
Feb 11, 2009 | JBL PB10 Subwoofer
Constant hum
CHECK THE ALL THE CABLES (RCA) .
i think missing ground sheeld .
or smoothing capacitors are leak.or power output section faulty.
can you poen the cover and check circuit board get wet anyhow,
nuwan
Sep 23, 2008 | Sherwood RD-6500 Receiver
Akai LCT42Z6TA 42-inch 1080p LCD HDTV Refurbished Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
