Actually the Green model same type as the blue. Its paired, its working and then it powers itself off, have to push power button to power back on and it repairs and continues. Have upgraded firmware. Its only 4 months old and only used for three months and just started doing this in last few weeks.
Start with the headset powered on. Press and hold down
the call control button while also rotating the multi function dial
upward (away from the light) until the indicator light on the headset
starts flashing red then green. When prompted for passkey, enter
0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter
(discontinued): Turn the headset on and the adapter off. On the headset
push in and hold the mute/volume dial until the indicator light begins
to flash. On the adapter press and hold the blue power button for 10
seconds. The light on the adapter will flash once after 3 seconds-
continue to hold the power button for another-7 seconds until the
light flashes red. If the pairing is successful, the headset will
sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued):
If you remove the battery cover from the headset and then remove the
battery itself. On the Green PC board itself there will be a letter
followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Simply plug the ac adapter into the wall, the laptop will charge the battery itself.
Keep in mind this... in general, a laptop runs at full speed when it is plugged into the wall. When most laptops are running on battery, things are running more at 50% capacity to save on power, this giving you more battery life. A dimmer lcd and slowing the processor down when not needed are common traits.
You can use the FN key (function key) and the corresponding dim control on the keyboard to adjust the brightnedd of the backlight. It should be marked on your keyboard in a different color, like blue or maybe green (not familiar with that models keyboard).
