Machine trouble Service call c3851. What does it mean?
    New Friend:
  • 28 Answers
Stop using printer until repairs are made
Posted on Apr 03, 2015
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Miolta c300 c3851
Fuser Error. Could be fuser or bad power.
Hold down [Utility/Counter] while turning the main switch on. Press [Reset] on the touch screen, and turn main sw. off/on.
May need firmware and/or software switch setting in service mode.
Change software setting. Service Mode System 2 Software Switch Setting
switch no: 50
bit assignment: 00000001
hex assignment: 01
May 21, 2014 | Konica Minolta bizhub C250 All-In-One...
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
The motor lock signal is detected for 6sec
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
Replace the polygon motor.
Replace the MCU PWB.
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
My bizhub 210 is coming up with an error mesage which says ,"CAUTION, MACHINE TROUBLE, SERVICE CALL COF32" Please may you asist me
its the code of ATDC sensor, that means your machine is having low deveolper, kindly change the developer to permanently get rid of this code. thanx
Nov 10, 2009 | Konica Minolta bizhub 180 All-In-One...
Konica minolta biz hub C250 need to reset admin code URGENT
you cannot overide the administrator password on the konicas the default password is 12345678 try that
Oct 30, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Mar 31, 2009 | Konica Minolta bizhub C250 All-In-One...
Malfunction Detected C-3851
Restart, holding utility key down and do troble reset, if everything is ok, the machine will work again, if not, call for service
Dec 18, 2007 | Konica Minolta bizhub C250 All-In-One...
Malfunction C 3851
C3851 Abnormal Low Temp. (Heater):
• The temperature of the Heating Roller Thermistor/ 1 (TH1) is lower than a given level of degree for 1 second or more uninterruptedly during
Ready mode, Low Power mode or printing.
• The temperature of the Heating Roller Thermistor/ 2 (TH3) is lower than a given level of degree for 1 second or more uninterruptedly during
Try resetting. To reset a Rank A error follow these steps:
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Dec 17, 2007 | Konica Minolta bizhub C250 All-In-One...
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
44 people viewed this question
k24674
jasbo
jasbo
