Question about Cell Phones
STUCK MY PHONE
SUDDEN STUCK MY PHONE. FRONT SCREEN LIGHT NO ,AND NO MOVINE TO THE SCREEN,
  • 46 Answers
Remove battery for 1 min and reinstall. Works most of ?the time
Posted on Apr 03, 2015
    Problem Solver:
  • 19 Answers
Install memory booster & uninstall the application which not use
How do I get my NozaTec 16gb to get past the "keep movine forward" screen. I've tried factory reset and I've tried the reset button on the back but nothing is working
If you look at http://www.androidtablets.net other people are having the same problem. The advice is to Press Power Button whilst at same time Hold down the Volume Button. Hold these down till the Tablet resets and all should be fine
Android Tablet Forum
Jan 15, 2015 | Tablets & eReaders
Not light
If you mean the back light of your phone is off, then it means the problem is from either the settings or the florescent of the phone is damaged, and the solution to a damaged florescent is for you to replace the screen if the phone. Also the flex of the phone can also cause this problem. Try to turn on the phone and flip the phone several times, if the light seem to come on or blinks for a moment, then it is the flex that need to be replaced, but if it does not come on in any way or at any time, then it means you will have to replace the screen of the phone.
First check from the settings of the phone if the screens light is not turned off. Once that is confirmed, then the next thing to do is to replace the screen of the phone. To replace the screen of the phone, please follow the steps below:
  1. Remove the four rubber stoppers surrounding the screen to reveal four screws. Remove these screws.
  2. You can now remove the front cover. To do this, use a credit card to lever the cover up. The cover clips on and the levering motion will unclip it. Start at the top, then unclip the cover at the bottom, then both sides.
  3. You should now have the front cover removed,
  4. Remove the rubber part which surrounds the camera. You should be able to lever it out with a fingernail or pen lid.
  5. Now detach the camera from the phone. Simply pull the ribbon away from the phone to release it.
  6. Now unplug the other ribbon. The ribbon attaches like a plug and socket. Simply lift it up to unplug it.
  7. The lens is held to the phone with double sided tape. Pry it off. It will be stuck on well so some force is required.
  8. You now need to peel the brown flexi cable part away from the edges of the screen. Again, it is stuck on with double sided tape.
  9. The screen will now be free from the rest of the phone.
  10. Now remove the brown flexi cable entirely and you are left with just the LCD screen. Note that the inner and outer screens are attached together so whether you are replacing the inner or outer screen you need the same one part. You should now stick the flexi cable onto the new screen.
  11. Reverse the whole procedure for reassembly.
To replace only the flex, follow the above steps to step 7 and take apart the lower part of the phone to access the other end of ribbon, that is the flex that need to be replaced. Hope this information helped. Thank you for using fixya.
Jan 18, 2011 | Motorola Mobility RAZR V3x Cellular Phone
Dropped phone now light won't come on for the face of phone
Hi, if the phone you are talking about is this RAZR V3, then what you have is a flex or screen problem. It either the flex is disconnected from the board panel or screen because of the sudden fall, or that you have damaged the screen itself due to the sudden fall.
In both situation, you have to take the phone to a repairer to diagnose which one of the problem is and fix it,,,
Take care
Apr 16, 2010 | Motorola Mobility RAZR V3
The phone is frozen of all of a sudden. its stuck on my home screen and it doesnt allow me to turn it off or do anything
Please take out the battery and wait for sometime. Then fix the battery and switch on the cell phone
Dec 20, 2009 | Nokia 2605 Mirage Cell Phone
Stuck on finalizing update and computer wont recognize.
yet i don´t know much about your mp3 ..
is there any reset "button" if so try that
May 25, 2009 | SanDisk Sansa m250 MP3 Player
Monitor menu shows up all of a sudden
If the butttons are not stuck on these monitors it could be something as simple as dry joints on the monitor somewhere. When this happens again lightly tap the front where the buttons are without pressing any and the sides then finally the back. If any of this tapping causes the menu to suddenly disappear and reappear then its dry joints. Otherwise it could be a number of problems. Post if it does not work and I will tell you more. Good luck.
Jul 23, 2008 | Relisys TL775 17" LCD Monitor
HELP ME!
try replacing the lcd or flexcable on your phone
Jun 14, 2008 | Motorola Mobility RAZR V3
Main display went black on enV
Yeah same with mine... the front screen went black.... it started to get lines up and down... then all of a sudden just the front screen turned off! :-(
Jun 02, 2008 | LG enV VX9900 Cellular Phone
throw ur monitors & get a new one heeeeeeeeee
Apr 25, 2008 | ViewSonic E70f 17" CRT Monitor
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
