Question about NAD Audio Players & Recorders
I have a nad 3130 amplifier which has been in storage for sometime. I've plugged it in and I have no power to the amp.
Ive changed the plug fuse and checked the 4 fuses inside and all seems fine. Is there anything else I can check.
    Scholar:
  • 54 Answers
If the fuses are good....do this.....
1...unplug the amp from the wall AND KEEP IT UNPLUGGED !!!
2 Turn the power switch on ( again , the amp is UNPLUGGED from the wall )
3 with an ohm meter or a multimeter set on ohms., measure the ohms across the ac cord that plugs into the wall....in other words...take one meter lead and touch it to only one " blade" that plugs into the wall and keep it touching the " blade".....while you are holding it there, touch the other meter lead to the other " blade " that plugs into the wall.....you should get a very low ohm reading ( 2-50 ohms )......if it is over that number, your transformer or your switch is open ( toast ). hopefully it is the switch as transformers are un-available......good luck, be safe, and if you arent sure....ask before doing something silly.....Rob
Posted on May 30, 2015
5 Suggested Answers
  • 4 Answers
SOURCE: NAD 370
Hi There is no circuit breakers inside. close to front panel on a left side under plastic cover is fuse (AGC type) . Before you change fuse look at four filter capacitors in the middle of unit!!! (close to power transformer on pcb) If they are white do not change the fuse and get unit to good service center( it must be someone who knows what they doing!!!) If the caps are different color (black ,purple) you can try to change fuse. Once again if capacitors are white do not use unit-fire hazard!!!! I'm long time service guy for NAD so trust me on this one Dariusz  dariusz70@verizon.net
Posted on Feb 13, 2008
Grubhead
  • 5487 Answers
SOURCE: my nad amp wont turn on - i've checked plug fuse so it must be something inside - was told it might not be worth fixing but i wuld like toknow what it is so i can at least decide. it's only 2 years ol
Yes it could be the internal fuse. If your lucky it might have just failed on it's own!
Posted on Jun 02, 2009
Grubhead
  • 5487 Answers
SOURCE: Marantz PM7200 Amplifier, wont switch on, no power
You can check the fuse with a battery and a bulb. Take the fuse out and use it to make a circuit with some wire, the battery and bulb. If the bulb doesn't light it has gone.
Apart from that other things to check are the power switch, to see if it works and the transformer.
It might be worth buying a cheap Ohm meter, if you haven't got one. You can check most of the parts in the power supply with it. By the way if the fuse has blown, buy a few as you might find it could blow again when you try it again. If it does you are looking at a device (such as a transistor) that as shorted and acting like it was a piece of wire. Which is easily found with an Ohm Meter!
Posted on Sep 28, 2010
Grubhead
  • 5487 Answers
SOURCE: NAD Electronics 7020e 4A fuse keeps blowing on power up
Well you are on the right course. I suspect you think the problem is in the power supply and it's probably not. I think that what's gone is either a transistor (or more) or an IC amp - if it uses one - on the main power amp stage. Look at the devices on the heat sink. I think that's where you will find your shorted device.
Posted on Dec 17, 2012
I plugged in my Nad amp to a socket last night, there was a flash of blue light and now it won't switch on. It is a NAD C316BEE Stereo Amplifier. Can you advise what has happened?
You need only look inside and follow your nose....The smell will lead you the faulty party, probably in the power supply. Just a power surge problem or something that's been going giving up the ghost.
Sep 06, 2011 | NAD C326BEE Amplifier
My mc2105 blows fuse as soon as you turn it on. this unit has been in storage nad the owner said it worked fine he lied I think but any way can you help
The Amp module might be fried, did you plug it into a speaker with an Ohms mismatch?
If the fuse keeps blowing, you need to get it repaired by a pro.
Jun 30, 2011 | Audio Players & Recorders
No sound from my NAD C325BEE amplifier
audio ic problem or component around audio ic.. good luck
Apr 26, 2010 | NAD C325BEE Amplifier
Nad c 370 no power
You need to look inside. There will be a fuse inside too. If your lucky it will restore the amp once replaced, but if it blows again you have a fault. You can track it down yourself if your any good, you might even see a burnt out part when looking for that fuse, otherwise get the repairman in.
Sep 20, 2009 | NAD C370 2-Channel Amplifier
Protection light is on
un plug rca
and disconnect all spk from amp and turn on if light dont come start with one rca at a time and one spk and connect and you will find the problem
Apr 11, 2009 | Car Audio & Video
Amplifier only making buzzing sounds
u r amplifires output system is not working properly somthig pcb break problem go to thew mechanic
Apr 05, 2009 | NAD D 3020 Hybrid Digital Amplifier
Knob for NAD amp?
Hi...
try your "local" NAD seller and ask them?
Contact NAD by email.
or
www.audiokarma.org
100's of users someone there should be able to help.
Jan 11, 2009 | NAD C370 2-Channel Amplifier
NAD 370
try to re-set mini circuit breaker inside.
Jan 21, 2008 | NAD C370 2-Channel Amplifier
208 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
