Question about Saws
Huskvarna k760 20011 wont start. oil in de compresor switch n spark plug hole.!??
    Sergeant:
  • 192 Answers
Check and see if you put the bar oil into the gas tank by accident the last time that you filled it up. Get back to me about this please.
Posted on Apr 12, 2015
  • 135 Answers
SOURCE: 1999 cadillac catera there is oil in the spark
oil in the spark plug hole means that you need new valve cover gaskets. replace valve cover gaskets and change spaekplugs and the car may start.
Posted on May 19, 2009
SOURCE: oil in spark plug holes
HAD THE SAME PROBLEM WITH MY DAUGHTERS CAR---CHANGED THE SPARK PLUGS AND OIL IN THE HOLES OF THE SPARK PLUGS WIRE TOPS--- CHANGED THE VALVE COVER GASKET AND ITS BEEN CLOSE TO 4 MONTHS AND NO OIL AT ALL IN HOLES---IF YOU LOOK AT THE GASKET YOU CAN TELL IT LET THE OIL OUT---THE GASKET SITS INSIDE THE VALVE COVER VERY SNUGLY--THE OLD ONE WAS VERY LOOSE---AS FAR AS OIL GOING INTO THE SPARK PLUG CYLINDER IT WILL BLOW WHITE SMOLE FOR ALITTLE WHILE BUT EVENTUALLY BURN OFF---HOPE THIS HELPS---DENNIS
Posted on Jan 25, 2010
leetamara
  • 702 Answers
SOURCE: oil on spark plugs holes
Replace the valve cover set.
Posted on Jun 10, 2008
  • 69 Answers
SOURCE: I changed the oil, spark plugs and valve cover
test to make shore you ignition coil is working" unplug any plug wire and then try starting it...you should her the ticking from the ark of electrisity from the coil to the engine block its self... first: be shore youve connected the spark plug wires in to the right slots on the ignition coil second: make shore the wiring harness just upstream from the air filter is connected"without it my montero want start" third:make shore all harmesses are connected and tight.... forth: now turn the car on..but dont start it.. and see if the check engine light goes off.... fifth:try giving it a lil bet of gas when trying to start..... thats all i can think of, srry for spelling...hope it helps
Posted on Jul 20, 2010
  • 132 Answers
SOURCE: My 2002 lexus Is300 is
PLS DO A COMPRESION TEST THEN YOU WILL KNOW IF YOU NEED TO REPLACE YOUR PISTONRINGS OR REDUE THE VALVE SEALS AGAIN
Posted on Oct 26, 2010
Huskvarna 225L weed trimmer weak spark or fire's every 2 or 3 pulls! Any suggestion?
If you have intermittent spark, your coil is going bad... time for a new one. Amazon sells an aftermath for a good price. Try this, remove the plug, spray carb cleaner in the hole, then install the plug. Give 2 slow pulls, then pull normally. If the unit starts for a few seconds, your problem is the carburetor.
Oct 03, 2015 | Garden
U tube chainsaw pull cord wont pull start
Some saws with autotmatic oiling will leak bar oil into the cylinder and cause this. Pull out the spark plug and hold the saw so the oil runs out of the spark plug hole. Pull the starter cord till no more oil sprays out of the hole.Clean the oil off the plug and start your saw. It will smoke more than normal till the extra oil is burned out.
Sep 05, 2014 | Homelite Garden
No spark on Huskvarna Rancher 55
disconnect any and all kill wires going to the coil... if you still have no spark then it can ONLY be the coil... if this produces spark then you have a kill system problem or your flywheel has no magnetism... and this can be the only solution as you do not have points/condenser or things just went full derp
Aug 27, 2014 | Garden
No spark with Huskvarna Rancher 55. New coil
anon re connect the kill switch. If this fail try connecting the two ends of the wire to the kill switch together.
Turns over but wont start
first check fuel, then check to see if it is fireing at the spark plug. if it is fireing at plug, check to make sure it is getting fuel. ( should be able to smell fuel on the electrode end of spark pug). If it is getting fuel, and spark, you may try removeing all spark plugs, then shoot some oil into each spark plug hole. Replace plugs, and try to start. If it still wont try to start, may be out of time. Does it pop, backfire when you are cranking the engine?
Nov 08, 2010 | 2001 Hyundai Accent
I recently change the blade on my mower and did not drain the oil prior to doing so , oil leaked everywhere now after the clean up and new spark plug and oil my mower wont start, how can i get it to start?
Make sure the air filter is not plugged with oil. Remove the spark plug (gapped 0.020") and check for spark--it should be blue and snappy. Squirt some fuel or starting fluid in the plug hole and try for start. If it pops several times, check the carburetor and fuel supply. There is likely to be considerable smoke when it does start, but that will quit. Hope this helps!
Aug 05, 2010 | Garden
Yard Machines 22 inch mower, I dumped it on its top over the weekend, bent the blade, replaced it, now wont start, did leak oil out of the air filter, cleaned it out real well still wont start
if you bent the blade most likely you bent the crankshaft too.
Remove the spark plug and pull the rope and remove excess oil from the spark plug hole
check the spark plug for spark if you have none then a flywheel key is sheered a more in depth fix.
If you get it started you may notice a whole lota vibration due to a bent crank shaft or maybe not?
May 18, 2009 | Mtd 22" Yard Machine Push Mower
Wont start
Hi and welcome to FixYa,
Absence of 2T oil in the reservoir in a two stroke engine is always bad news. Probable cause of no start:
  • oil level sensor knows no oil, triggers CDI not to fire, pls check if you have spark at the plug;
  • if the engine was run previously with no 2T oil (unknown to you), then it is possible to have broken rings. You can check compression by removing the plug and covering the hole with a finger. Start and determine if their is compression strong enough to push your finger away from the hole and produce a pressure release sound;
  • if there is spark and compression is good, you may need to de-carbonized the cylinder head and the top of the piston.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 27, 2008 | 1991 Gilera Saturno Bialbero
Saws Logo
173 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
