Question about marlboro.com
How do i change my security question - marlboro.com
  • 615 Answers
Once logged in, you should be able to make changes in the "profile" section.
If you don't know your logon, there should be a selection for "forgot logon" or "forgot password'>
Posted on Apr 03, 2015
  • Lawrence Boes
    Lawrence Boes Apr 03, 2015
    i cant log in i forgot my password and security answer
Nokia 6300 imei no 356960011934838 master restor code
Changing the security code
Of course, if any potential phone thieves are reading this, they'll now know the default security code is 12345.
To change the security code, go to Menu > Settings > Security > Access codes > Change security code. When prompted, enter your current security code and click OK. The enter your new security code (a PIN between 5 and 10 digits in length), click OK and enter the new code again to verify it. Click OK and you'll see the message 'Security code changed
or
*#7328748263373738# resets security code.
Default security code is 12345
Jun 27, 2011 | Nokia 6300 Cellular Phone
Security keyuard refresh
if you want change it just go to seetings security settings change access codes change security code firstly type your default security code 12345 and type the new security code for twice press ok and cogratulation
May 21, 2011 | Nokia 7610 Supernova Cell Phone
What should i have to do for change security code?
Your Nokia phone was designed with a default security code of 12345.
To change it,
1. Go to 'settings' on your phone.
2. Then 'security'.
3. Then 'access codes'.
4. Then 'change security code'.
5. When you select to change security code,
it would prompt you to enter the security code (initial one, ie. 12345).
6.When you have entered the intial one, it would prompt for the new code.
7. Enter any 5- digtit new code of yours.
8. It would prompt for a confirmation.
9. Re enter the new code.
And your security code is changed. But remember to use number you can easily remember.
Hope that was helpful?
Regards.
May 20, 2011 | Nokia N73 Music Edition Smartphone
Need security code for my phone
The default security code for Nokia is 00000, but you can change it.
Menu>Settings>Security settings>Change access codes>Change security code>Enter a new security code
I hope my solution would be of immense help to you.
Best regards
Aug 20, 2010 | Nokia 5000 Cellular Phone
How to identify security type on my belkin wireless router relative to nintendo wii security type options
For nintendo wii , you can use the security WEP or WPA ( PSK ).
These 2 security types will works with WII. If you put WEP,then 10 digit number will be the security code.
To change the security on the wireless network, you will need to open the set up page of the router.
Once you change the security on the router, it is recommended that you will change the wireless network name SSID. after changing the wireless settings , you will need to connect to the new wireless network on all your wireless devices like laptop , wii.
Click Here for step by step instructions
Mar 05, 2010 | Belkin Computers & Internet
Ip address wrong, showing 192.168.254.1
Solution Overview
This article explains how you can avoid having to run the Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) after making changes to the router's security settings. The need to change these settings can arise if users forget their network key/passphrase or router web server password or if you have security concerns.
Printer response to security settings changes
The printer will respond with a flashing orange (pattlnk_6172008_1844-orgblksml.gif) Wi-Fi indicator light after the following actions are performed on the network or router/access point (AP):
  • -A change to the Service Set Identifier (SSID) or network name.
  • -A change to the security type (none, WEP, WPA, or WPA2 personal).
  • -A change to the security network key/passphrase.
  • -A hard reset of the router followed by entry of security values that are different from the original values.
  • -The printer is moved to a network (AP) that has different security values but already has installed drivers and created ports. NOTE: Port reconfiguration may be required in this case. Click here for instructions.
In order to rejoin (associate and authenticate) the wireless network (WLAN), the wireless client (printer) has to be reconfigured with the router's new SSID, security type, and network key. This requires connecting the USB configuration cable to the host computer and running the Wireless Configuration Utility or Wireless Setup Assistant to apply the new security settings on the printer's wireless network adapter.
Solution: Change the printer settings first
Change the security settings on the printer while it is still communicating on the network before making the changes on the router. Understand that this will cause a temporary change in the Wi-Fi indicator light from pattlnk_6172008_1952-tn_grnsolproof.jpg to pattlnk_6172008_1844-orgblksml.gif. After you have made equivalent changes on the router, the printer's Wi-Fi indicator light will return to pattlnk_6172008_1952-tn_grnsolproof.jpg.
Procedure: How to change security settings via the embedded web server
If you change your AP security settings frequently, this procedure is for you.
  1. Open your web browser application and enter the printer IP address into the web address field, i.e. http://ip_address.
  2. Click on Configuration.
  3. Click on Wireless.
  4. Enter the SSID, security type/encryption, and network key that will be used to configure the router.
  5. Click Submit.
Jan 16, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
I want to change my security code. Right now its the same default code 12345. But dont know how to change it as i desire?
To change your security code from the default, follow these steps carefully;
  1. Press Menu
  2. From Menu, go to Settings,
  3. From Settings, scroll to Security settings
  4. From Security Settings, go to Access Codes,
  5. Press Access codes and you would see Change Change Security Code.
  6. Press Change Securty code and you would be asked to enter your old security code (which is 12345, the one your are presently using) and thereafter, you would be required to enter the new security code.
I wish you the best and don't forget to rate this.
Dec 29, 2009 | Nokia 6233 Cellular Phone
My security code and i want to unlock it
Enter the lock code instead of the security code. After then to change the security code.
  1. Go to menu and there open settings.
  2. There open security settings.
  3. There will options such as change lock code or change security code etc.
  4. If you have forgot security code then you can't change it, better change lock code as your desired password.
  5. To change first get into change lock code and enter old lock code and after that input new password and its all done.
Aug 14, 2009 | Lands Phones
Help me pleace phone code nokia 5800 Xpres musik
Go 2 ur SETTINGS->PHONE SETTINGS->SECURITY SETTINGS
->CHANGE ACCESS CODES->CHANGE SECURITY CODES.
if u hav not use ur security codes b4 this.key in 12345.after tat key in ur new security code no.
avoid ur sims card from bocking.change ur security level.use PHONE LEVEL.
i hope u can do it. ;)
Dec 24, 2008 | Nokia N73 Cellular Phone
Resetting Security Code
i forget my security code my imei is 355383007782969
Jul 17, 2008 | Nokia 1100
marlboro.com Logo
93 people viewed this question
Top marlboro.com Computers & Internet Experts
Terry Hair
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a marlboro.com Computer and Internet Expert? Answer questions, earn points and help others
