Question about Agfa 1236U Snapscan 1236U Flatbed Scanner Usb P/N: 1236U - O
My transparency scanning won't work.
"hard copy: scans work, transparency doesn't.
Won't scan, light doesn't come on
Make sure the printer can copy (without computer). If you can make copies, the problem may be the computer or the USB cable. If the printer does not copy also. The problem is in the scanner or in the flat cable.
Apr 10, 2012 | Canon Office Equipment & Supplies
How do I scan transparancies? With the holder in place on the flat bed the whole frame scans and not the slide.
You need to put a piece of white paper, the same size as your slide on the back of your slide. Your scanner doesn't recognize the edges of the transparancy (it is looking through it), so if you place a white paper on top of your transparancy it wil recognize the edges.
Nov 15, 2011 | Epson Stylus RX500 All-In-One InkJet...
MY SCANNER WILL SCAN PRINTS BUT NOT TRANSPARANCIES THE SCANNING LIGHT WORKS ON PRINTS BUT NOT TRANNYS, ANY IDEAS PLEASE
Flatbed scanners that can scan prints and transparences had two light sources.
One for normal prints (ie reflective light source, the light shines from under the glass to the print/photo and reflects off this print/photo to the optical sensor).
On a scanner that can scan transparences there is a second light source in the lid that shines through the transparences pass the glass to the optical sensor. The light source under the glass is not used in this case.
The scanning software automatically selects the right source when you select to scan prints or transparences.
Sep 06, 2009 | Umax Astra 6450 Flatbed Scanner
EPSON V500 trying to scan 2.25 x 6.5 transparancy
its possible they are right, But try puting acoulpe of sheets of plain white paper behind the transparency before copying as a buffer . The scanner is seeing the transparency reflected back causing distortion. with the paper blocking the reflection, it should scan perfectly
Jul 11, 2009 | Xante Accel-a-Writer 4N Laser Printer
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Jan 22, 2008 | Epson Perfection 3200 Photo Flatbed...
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
Scanner incorrectly reads frame position on film
Yes there is
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Epson perfection 4990 photo scanner
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Scanner wont scan transparencies properly
I have the same problem with my 4990. This began when I moved to a new computer running Vista. I've updated all drivers to the latest version including Epson Scan for Vista but the only thing the 4990 "sees" is reflective documents. Negatives are not recognized at all. I know this is probably a different problem from what you are having but the effect is the same.
Apr 27, 2007 | Epson Perfection 4990 Flatbed Scanner
35mm Color Slides
Here they are for Mac and PC
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
Mar 15, 2007 | Epson Perfection 3170 Flatbed Scanner
Agfa 1236U Snapscan 1236U Flatbed Scanner Usb P/N: 1236U - O Logo
65 people viewed this question
Top Agfa Office Equipment & Supplies Experts
Greg Cann
Greg Cann
Are you an Agfa Office Equipment and Supply Expert? Answer questions, earn points and help others
