Question about Ezip The E-450 Scooter
When i put it on charge it wont charge
Every time i plug in my charger it shows a green light 6-8 hrs later i unplug it and it says low battery and it just stays in one place
Yea mine wont charge right i put the charger on it the green thing wont charge up so do i have to buy a new charger or what? please and thank you
U plug in the a/c power charger for the portable DVD player have power and work?Yes,than the litium battery is dead.Take out of the a/c charger like 4 or 6 hrs later dvd player have any battery power at all?No?Tries websites like Amazon.com,Ebay.com to buy a new litium battery or a compatible one for the replacement.
Feb 26, 2011 | RCA DRC6309 9 in. Portable DVD Player with...
The charger says that the battery is charing and the green light is on after charging for over 6 hrs it still dont want to move whenever you push the gas. So i tried unplugging the battery and left the...
Most likely Neither. It is usually the Gearbox has gone bad. It is easy to replace, Peg Perego has a wonderful tech support they can walk you through it 1800-728-2108 if you need parts they handle that too, or you can go to www.mypegperegoparts.com
Feb 13, 2011 | Peg Perego John Deere Gator HPX Ride on...
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
My irobot (Roomba)is only working for 10 mins then
It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
May 12, 2010 | iRobot 4150 Roomba Vacuum
WHy is air hog battery charger flashing red
I had a Storm Launcher battery that was unused for sometime and when I plugged it in to the charger, the light flashed red. I checked the voltage of the pack and it was down around 2.5V....from 7.4V. I figured the "smart charger" thought it had a dead or shorted cell and wouldn't kick in the charging circuit. I McGyver'd the two probes and alligator clips to connect the pack to a 9V. NiCad "dumb" charger. The light came on showing a charge and I left it for 5 mins. Unhooked it and checked the voltage. It was now 5 volts...supposed to be 7.4...but much better than 2.5. Plugged the pack into the AirHogs charger and the green light started flashing, indicating a charge. Later I got the double-flashing and 10 minutes after that FULL charge! Just needed a boost to start the smart charger.
Apr 03, 2010 | Air Hogs Radio Controlled Storm Launcher...
Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Jul 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Peg perego 12 volt battery
Although what the previous post is correct, if the battery is new, and if you have the peg perego charger, you need to charge it 36 hrs the first time. After that, you can charge overnight. The peg perego charger has a small light on the front.When you plug the battery in the plugged up charger, it will show amber. When battery is charged it will show green. Don't leave it plugged up, after the first charge, longer than 24 hours.
Oct 14, 2008 | Peg Perego 12 Volt Rechargeable Battery
Battery problem or camera problem?
A new battery should help you to solve this problem.
Aug 07, 2007 | Casio Exilim EX-Z57 Digital Camera
Ezip The E-450 Scooter Logo
73 people viewed this question
Top Ezip Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you an Ezip Cycling Expert? Answer questions, earn points and help others
