Question about Kenmore Washing Machines
Mechanical timer (3351811B)
Just installed a new one. There is a notch that is likely used to set the timer for the various settings. Does that notch go at 12 o'clock?
  • Kenmore Master
  • 744 Answers
Hello Stephen;
My name is Peter. I am a retired field service appliance technician.
Sorry I have been absent from this site. I have been busy doing service calls on the side.
You have probably figured it out by now.
If you have any problems with your appliances in the future call me.
Generally I charge $50.00 per job plus parts. I use my contractor license to get parts for less than you can purchase them.
Peter Goodwin
Glen Burnie, MD
443-306-1362
Posted on Apr 25, 2015
Timer stops intermittently during spin cycle
When it stops try wiggling the timer knob if you get it to start most likely have a timer problem not connecting inside the timer. Hope this helps
Jan 03, 2018 | Kenmore Whirlpool Washer Timer 3351811...
052-8835-2 Noma Block heater timer
Copy following link to identify various timers and download possible manual. Timer was originally made by Intermatic.
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
http://waterheatertimer.org/pdf/Intermatic-HB65R-timer.pdf
N1506 is 2-button timer and is called a block-heater timer.
This timer has 1 year limited warranty through Coleman.
http://www.colemancable.com/contact-us/technical-support/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 22, 2012 | WOODS INDUSTRIES 2001 OUTDOOR MECHANICAL...
Need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Sep 10, 2012 | Hardware & Accessories
I have a sundial mechanical dual timer. I know how to set it and everything but the mechanism stops turning so the power to my lights is left on or off longer than than they are supposed to be untill i...
If the dial is no longer rotating, then the small clock motor has stopped working.
Check if timer works in another outlet.
Buy another timer at local store. Then when it stops working, buy another and return defective timer in new package.
Some timers offer 1/2 hour increments, others offer 15 minute intervals.
Vacation timers look very similar, but they cannot be programmed, and operate at random times.
Copy following links to see various analog timers:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Apr 20, 2012 | Home
I'm using the woods 59200 mechanical timer to automatically open and close a chicken coop door. I can't for the life of me figure out how to set it. Help!
Woods 59202 is 7-day analog VACATION timer and cannot be set.
Vacation timers are preset to turn on-and-off at random times so it looks like somebody is home when you are away.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59202
You might want the 59201 analog timer which can be set for on-off times over 24-hour period. Minimum on-off is 15 minutes.
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
If you need a 7-day timer, buy a programmable instead of analog. Wooods 59377 or Intermatic DT630 heavy duty
http://www.amazon.com/Woods-59377-Digital-Appliance-Settings/dp/B000IKQRTU
If you have analog plug-in timer, open following link to see how to set timers:
Jul 05, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
Hi i have a new DeLonghi Dragon 3 heater. The timer seems to work opposite to your instructions - i.e. the instructions indicate that the notches must be pushed to the outer ring to indicate the operating...
This is from the instruction manual online:
To set the heating periods proceed in the following manner:
- Check the time by your watch. Supposing it is 10.00 a.m. turn the numbered dial of the
time-clock in a clockwise direction until the number 10 coincides with the reference mark s
on the time-clock. Set the time period during which you wish the appliance to work by
pushing the notches towards the centre. Each notch corresponds to a period of 15 minutes.
At this point sections will be visible corresponding to the working periods.
Set in this way the radiator will function automatically every day during the set period.
(Important: the plug must remain connected to power supply).
- To change the programmed time period, just bring back the black notches to their original
position and set the new working periods required.
- If you wish the appliance to function without programmed working periods push all the notches
towards the centre. In this case, to turn the appliance off totally the plug must be pulled
out apart from switching off, so as to avoid unnecessary working of the timer.
Jan 29, 2011 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
My Raindrip water timer R672C goes click click click click when new batteries are installed and neither turns on the water or turns it off. How can this be fixed?
i reset mine (trying several of the surrounding notches/settings b/c i don't think the dial is all that accurate). it worked until i turned it back on, then i just pushed the faceplate and the clicking stopped.
i have to see what happens now that i've reset the intervals.
http://www.raindrip.com/resources/information/catalogs-and-manuals/
Aug 02, 2010 | Raindrip R673CT Digital Water Timer
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
Washing Machines Logo
63 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
