Question about GPS
I have a furnogp31 gps and want to hook my plotter to it what wires do i use.
  • GPS Master
  • 696 Answers
NMEA out (+) and (-) from your GPS to NMEA in (+) and (-) to your chartplotter gets it done. Hope this is helpful.
-Steve
Posted on Apr 03, 2015
I have problems with my plotter Raymarine Rc 435 chart plotter.This plotter can not location my ship to do.What is problems?
Be sure there isn't any aluminum in close proximity to your GPS antenna, or that your antenna is not to close to other powerful electronics. Aluminium reflects electromagnetic signals and other electronics emit EM fields as well causing disruption of your GPS signal reaching your antenna.
Sep 26, 2014 | Raymarine Rc435 Chartplotter
Does it have achart plotter
Out of the box, no. To get GPS/Mapping/chartplotting features, you have to hook up a separate LGC-12S 12-parallel channel GPS receiver/antenna device which is sold separately.
Mar 11, 2011 | Lowrance LCX-15MT GPS Receiver
How to hook up my lab top to my gp-7000f
If it does not have a usb port then you need to have a sd card reader on your pc and use that to transfer data
Mar 03, 2011 | Furuno Gp7000 Nt Gps Waas Chart Plotter...
My Raychart won't take a fix. I've been advised
Maybe you backup batterie inside you plotter is low If yor plotter shows you that you are somewhere in Afrika on the atlantikcoast you have to change only the battery inside the plotter it kost few euro.
The next possibility is that you have problems with you extern gps antena look after broken kable or try it with another Gps antena
Oct 13, 2009 | Raymarine GPS
C120 displays NO DATA SOURCE in the radar section of the screen. ohns resistance test checked out. what else can it be?
1. you must have the latest software 4.29 the new scanner dont work with the old Software.
2. Be shure that you have really put in the connector of the cable inside the plotter its not so easy.
3.
try the plotter on an nother boat with an working system than you will know if its a problem with the antena or Plotter
Aug 06, 2009 | Raymarine C80 GPS Receiver
My plotter seems not to output NMEA to my DSC radio and auto helm
Your plotter can talk to you Radio and your pilot. It sounds like one of two things.You must go into the system setup menu and turn on the nmea sentances. You will need to turn on RMB, RMC, GGl at least. You can turn on all the sentances if you like it does not matter. If this does not fix, check color of wiring is correct. Remember you have to go from NMEA + out (on plotter) to NMEA + IN on Radio.Then you need NMEA - out(on Plotter) to NMEA - IN on Radio.
You can look at the sentances wirth a multi meter coming out of your plotter. You put meter in DCV and connect across the NMEA out lines. You will see the meter move every second or so as it send a sentance.
Jun 09, 2009 | Raymarine Raychart 435 GPS Receiver
Can I use my furuno gps navigator to supply position data to my rdp-139 chartplotter and if so which wires need to be connected
Yes the output forom the Furuno GPS (like a GP31) will be yellow and green, hook these to theinput on the plotter blue (or black) and white. Use Data1 on potter as the input and select a nav source of "ALL" in setup menu.
Jun 05, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Furuno 1833C/Dgps37 Plotter creeps
Try adjusting the GPS position offset in the GPS Sensor Settings Menu.
Jan 11, 2009 | Furuno 1833C/NT GPS Receiver
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
Wiring of seatalk instruments
OK, you are confused. Seatalk is a bus system, using 3 wires , (power +, power-, and Data.) red, bare and yellow repectively. So Red and Bare are 12V and ground. Since the 125 shows a green light, it is getting power and outputting data. but is it seatalk?? to make a 125 Seatalk, you must hook red and green together to 12 V, so check that first. if green is grounded or not connected, that is the problem (or one of them)
Next divide system to its' simplest terms, so hook the GPS straight to the display ST60, and see if it works red to rd, yell to yell and bare to bare (sometimes black) One by one hook the others into the chain until they all work or failed device takes down Seatalk network. If you are missing 12V on a seatalk leg, check 5A fuse in course computer. If you have a pilot, you have a course computer, unless it is ST4000 wheel pilot, and then the brain is the display (course computer is built in to ST4000 display)
Sep 01, 2008 | Raymarine RL70CRC GPS Receiver
GPS Logo
52 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
