Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
How do I fix black screen on windows 7 PC
I cannot communicate with my PC, I have only black screen with blinking cursor on upper left corner. I was able to put it in diagnostic mode and all tests passed but wasn't able to boot it.Also, I cannot put PC in safe mode to repair it (I used repeatedly F8, am I wrong?-is there another way). Regards, Ned. Please help. My e mail address is ned92@sbcglobal.net
  • 195 Answers
Remove all other connected devices beside the keyboard and mouse and remove any disc in the dvd drive then try and boot. If the system boots connect the devices back to the computer one by one till the problem duplicates, then you will know what's faulty. If the problem is still there after removing all devices besides keyboard and mouse disconnect those as well. Just an FYI these HP desktops were notorious for failing motherboards. You might give the motherboard a visual inspection for bulging or leaky capacitors.
Posted on May 06, 2015
  • 36 Answers
SOURCE: stuck in safe mode with black screen
spywaregard 2008 is malware, a parasite if you will
http://www.pcthreat.com/parasitebyid-7159en.html
the last 1/2 of this article will run down a list of files you need to delte to get rid of this nasty little bugger. You can also download various tools to remove it, but it is dependent on your comfort level. if you are comfortable searching for files and changing a couple of registry keys, then by all means, manually is the way to go. If not, you will not have a hard time finding a tool to get rid of this
Posted on Jan 09, 2009
  • 1602 Answers
SOURCE: black screen with flashing small line in upper left corner
PULL OUT THE MEMORY AND PUT THE OLD ONE BACK IN AND SEE IF YOU FIX THE PROBLEM.
Posted on Feb 12, 2009
  • 59 Answers
SOURCE: blinking cursor
Try new memory. That has fixed a problem I had with a different computer. But might work.
Hope this helps.
Posted on Mar 01, 2009
Kiranbala
  • 91 Answers
SOURCE: HP Compaq d530 SFF PC Desktop. Black Screen and Cursor blinking..
Try to enter in to BIOS by restearting the notebook (Pressing F2 function, if the notebook enters in to bios then no need to worry. after theat i suggest you to reinstall the notebook to original factory settings dy the recovery disks.
Posted on Mar 07, 2009
  • 101 Answers
SOURCE: won't boot, says insert disk & press enter.
this means that the operating system is missing
and you will need to reinstall windows
try to borrow a disk and reinstall windows
hope this help
Posted on Sep 19, 2009
Testimonial: "Thanks, answered all my questions."
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
When I push the power button, the main dell start up screen comes on followed by a black screen with a blinking cursor in the upper left corner. It uses Windows 7
Remove any CD's or USB drives 1st.
Sound like its trying to load and can't find hard drive, CD, or USB device. You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key to press during boot. Make internal hard drive first. Save and restart. Reseat hard drive if it does not show up in BIOS.
Oct 05, 2012 | Dell Inspiron 560 PC Desktop
Acer desktop with black screen and line blinking
I'm thinking from what you describe that you are just looking at the cursor blinking in the upper left corner of the screen.
You haven't said what you did or what you are trying to do, but I suggest you turn the computer off (just push the power button in for about 7 seconds) and then restart it after about 15 seconds. If it doesn't start, go through the process again but this time, after you turn it on, tap on the F8 key. Like tap---tap---tap and keep doing that until you get a black screen with a white menu on it. Use your arrow keys to select "repair your computer" that you will see if you are using windows 7.
This should repair you startup problem.
Mar 22, 2012 | Acer Aspire Z5600 (AZ5600U2092) 23 in PC...
One minute it was working fine, the next it was a black screen with the cursor blinking in the upper left corner. I tried re-booting it, but it just goes back to the black screen with blinking cursor. Any...
Are you getting the Acer logo on start up? If so you might have a software issue on the hard drive, or the hard drive itself is defective. I suggest using your recovery disc to re-install windows and drivers providing you have them.
Dec 18, 2010 | Acer Aspire One PC Notebook
Black screen with blinking cursor upon start up
You don't say what Windows are you using.
Anyways, it seems like you have a corrupted BOOT problem.
On Windows Vista and Windows 7, you can insert your Windows installation CD, and choose the "Repair my pc" option.
Windows will do it automatically fro you, and you'll be up and running in a couple of minutes.
Dont forget to rate this answer if it helps.
Jul 18, 2010 | Dell Inspiron 531s Desktop Computer
My monitor has a black screen with a cursor blinking in the upper left hand corner; what is the issue?
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Oct 11, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Windows vista won't start
Open your system and fix any cable inside the system, maybe gor a loss connection. i guess that hard drive not detected. so fix it. please tell me what happen next i will surely give you more solution in it.
do not rate me if this not solve the problem.
at last remove and clean the memory fit it exactly to the slot.
best regards,melnavz
Apr 09, 2008 | Gateway GT4022 PC Desktop
Computers & Internet Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
