Question about Pool & Spa
I cant get the old check valve off? - Pool & Spa
  • 1,631 Answers
Cut it out & install a new one, that is the normal thing to do.
Posted on Apr 04, 2015
Cant find the plug for the control actuator on a Ford E150. Door is not switching so only cold air is blowing.
What year E150 ? Manual or automatic HVAC ? What door isn't switching ? Mode door , temp. door ? Some ford's have a valve under the hood hooked to heater hoses called hot water valve , allow hot coolant to go through the heater core . Ford Explorer 1992 heater control valve install Explorer E150 doesn't matter ford used on all there vehicles ! Some are vacuum controlled others are controlled by a cable !
Sep 29, 2016 | Ford Cars & Trucks
Husqvarna 18538 engine starts smooth but starts popping like backfiring . Trying to figure it's old gas ? Just serviced the machine.
to most owners a service means change oil. plug ,and clean air filter
drain the fuel tank ..new gas
cant see the carby .. if it has one
undo fuel drain nut on side of carby bowl
popping ....check valve adjustments
if no better
you may have a burnt valve
May 31, 2016 | Husqvarna Garden
Egr valve orifice washer
Contact dodge parts with the VIN NUMBER
Mar 02, 2014 | 1988 Dodge Dakota
Cant change valve core cabnet to close c&d remover does not fit high side ruud rheem condensor
I would pump it down to the compressor then change out the valve instead of going through the whole recovery process and make sure the service ports are closed tight
Jul 26, 2012 | Ruud Handler Air Conditioner
On my 2001 ford explorer sport trac the overdrive light is flash what the problem
Generally when the OD light flashes its stating that theres something wrong with the transmission.
Explorers were notorious for their transmissions having problems after wear and tear. Being 10 years old i wouldn't doubt that the valve body is going on it. I'd get the valve body checked out.
Be weary, if the car starts feeling like it cant accelerate but the RPM is increasing, that means your transmission is going bad.
Check Fluids for volume and color. If it looks really dirty or low, i'd add some fluid or get it flushed and see if that helps. If it doesn't the transmission will need to have its trouble code checked and have valve body looked at.
Mar 01, 2011 | Ford Explorer Sport Trac Cars & Trucks
How to fix loud lifter noise?
take off the valve cover check make sure nothing broken get a tool from auto zone measure the gap between the lifter and the valve sorry cant think what tool is called theyll know and they tell how much gap should be measure each valve use a small flathead to tighten bolt on top lifter to proper spec this should fix it replace valve cover gasket while apart cause after get it back togethor old one probably leak hope this helps
Sep 14, 2010 | 1994 Nissan Pathfinder
Cant start the burner pilot on a older unit approxment age is 50 years old Gas valve has gas going to it,, but no gas comming from pilot primer, all valves are turned on correctly..
check that the pipes are clear of any rubbish or whatsoever you can clean the pipes by using a small ear bud or a match stick, check that
Mar 10, 2010 | Heating & Cooling
How to fit a new double valve on hotpoint first edition washer
Some valves are held by screws some twist on ,if the valve its self is okay you can Gently remove the Coil and fit the new one as its normally the coil that goes. It pull off with a srewdriver Gently otherwise valve may suffer damage...
Feb 08, 2010 | Hotpoint First Edition WMA12 Front Load...
Cant get the old valve cartridge out in order to put in the new one
if it a moen needs a special tool to remove old one but they supply it with the new cartridge if other brands some times hard water deposits actually weld the old one in place may need a lot of persuasion and penetrating oil
Nov 22, 2009 | Plumbing
Kenmore washing machine old model
depends on how old.. but first Check lid swith for not spinning.. No hot water take hose off make sure you getting hot water to the washer... if water to washer.. water valve probley bad
Aug 26, 2007 | GE WJSR2070B Top Load Washer
Pool & Spa Logo
41 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
