Question about Optics
Is the trigger adjustable? - Optics
    Problem Solver:
  • 19 Answers
Yes
Posted on Apr 03, 2015
    Habit-Forming:
  • 191 Answers
Maybe not, do a Google search for your particular gun. Safety comes first.
Posted on Jun 02, 2015
How can I adjust the trigger pull?
Hello, here is website for adjusting the trigger:
How to Adjust Adjustable Triggers
Please rate my answer, give me thumbs up , pls, thank you.
Nov 30, 2015 | Optics
How do i adjust the trigger pull
Very carefully as if you get it wrong
Most rifles come with limited adjustment to the trigger pull down to 5lbs if you are lucky so to get them lighter say to 2.5lbs final stage you either have to get a after market trigger or
Stone the surfaces of the trigger but doing this is very very dangerous if you make a mistake
Take the weapon out of the action and look at the trigger for small screws or Allen bolts that adjust the sear engagement and if the trigger has them adjust them a little bit and test trigger pull and safety catch to see if it dry fires when you operate the safety if every thing goes OK repeat until you get desired pull weight or run out of adjustment then think about a professional trigger job as if you get it wrong you will start putting rounds in unexpected places
I have gone on about getting it wrong a lot as I have seen weapons with truly hidious trigger jobs that have fired by closing the bolt or setting the safety to safe which has given the other shooters a nasty surprise and the poor nut on the gun a shock
Jun 09, 2015 | Miscellaneous
How do I adj. the trigger pull on my wetherby .204 cal. rifel
If it came with an adjustable trigger easy to do take action out of stock and check trigger for adjuster screw should have +/- arrows and don't go below 16 oz pull
if not the rifle will have to go to a competent gunsmith or to a wetherby service centre to have the trigger faces honed
Or fit an aftermarket adjustable unit like timney
Feb 21, 2015 | Optics
I need to adjust my trigger pull on a Ruger Model 77 rifle.
If you'll look up into the trigger assembly inside the trigger guard you'll see a set screw. I've got one of those old Rugers and supposedly that set screw is for adjusting trigger pull wt.
Nov 07, 2012 | Refrigerators
Bought new poulan pro PP125e weed-eater and it has an accelration problem. Manual says may need carburator adjustment. Do you know how to adjust?
new --under warranty -- take it in for a warranty service and adjustment
they will know how to adjust it as well as will have the correct tools for the job
Jul 26, 2017 | Garden
Pull the trigger, no nail, only continuos air until I release tyhe trigger. not jammed, gun is clean, very new. acted that way right out of the box then it worked and then not and so on, worked...
Safety foot and lever inside of trigger are not pushing the trigger pin all the way in. To verifty that the gun will fire, remove the nails to allow for dry fire. Remove the trigger to reveal the trigger valve. Hold the gun against old coiled rubber hose or soft wood. Very quickly depress the trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is fully depressed when your bump fire. If the gun will not fire after adjustment, remove the head and lube headvalve/orings with silicone paste lube.
Sep 03, 2011 | Stanley Bostitch Mcn150 Strapshot Metal...
Bostitch F21PL. Air to gun, but when trigger depressed nothing. If I reach below the trigger and push up the piece from the front of the nailer, it will fire the nail (as long as tip is making contact and...
that is the safety that you are pushing up
apparantly the safety is not going far enough up to disengage.
there should be an adjustment know near the trigger or nose to adjust the safety out further, therefore making proper contact
Nov 24, 2009 | Saws
Nothing happens when you load paper to staple. It is a swingline electric stapler model 270
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
Mar 05, 2009 | Staples Swingline® 36115 Staple Guns Tools...
D51844 Framing Nailer won't fire
Adjusting the depth of the nail also changes the amount of pressure that is applied to the trigger pin. This is not actually a problem with the adjustment, however indicates that the orings in the gun are not completely sealing or is lacking lubricant. Adjust depth so that maximum pressure is asserted against the trigger pin. The trigger pin must be pushed all the way in very quickly to fire the gun. Test by removing the trigger and depressing the trigger pin by hand all the way in quickly. Enjoy
Dec 05, 2008 | Dewalt D51844 Framing Nailer
Optics Logo
60 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
