Question about Liquid Performance Premium Brake & Parts Contact Cleaner - 14oz
We had a new brake controller installed and now our engine light is on and the message says reduced engine power.
  • 2,039 Answers
High shiley year and model would be great but ill give you and example of what to do you got to clean the throttle body
Posted on Apr 04, 2015
Check engine and service traction control light on in 3rd limp mode
Check engine light on , check DTC'S - diagnostic trouble codes ! Check Engine Light On If not familiar with this take it to a ASE certified repair shop or dealer . 3rd limp mode ? Do you have a message in the DIC - driver information center , reduced power mode ?
ENGINE POWER IS REDUCED
Engine Control Module Description for the 4.8L, 5.3L, 6.0L and 6.2L engine
Apr 16, 2016 | 2008 Hummer H2
Reduce power light on has no throttle and keeps giving throttle accuator cdes
2003 Silverado 2500HD REDUCED ENGINE POWER - Discussion on Topix
www.topix.com > Top Stories
Dec 28, 2009 - 20 posts - ‎12 authors I have replaced the throttle body, had the wires re-connected and .... The gauges all went wild and reduced engine power displayed on the dash. I looked it .... The truck just went to idle for no reason and it keeps happening. 2003 Chevy Trailblazer-CHECK ENGINE LIGHT AND ...
Dec 23, 2011
Reduced Engine Power message
Jul 29, 2008
2003 Chevrolet Silverado - Reduced Engine Power
Nov 3, 2007
Trailblazer - Reducted Engine Power
Aug 3, 2006
More results from www.topix.com
Reduced Engine Power Message Displayed on GM Vehicles
www.underhoodservice.com/tech-tip-reduced-engine-power-message-dis...
Dec 10, 2012 - Tech Tip: Reduced Engine Power Message Displayed on GM Vehicles ... Model year 2008-'10 vehicles must have the engine control module (ECM) reprogrammed ... Do not drop the electronic throttle control components.
Oct 28, 2015 | Cars & Trucks
What does it mean when my reduce engine power light come on
Not sensor , SENSORS ! This message reduced engine has to do with the electronic throttle control !
Throttle Actuator Control (TAC) System
Drive by Wire Function and diagnostics by Wells
Oct 07, 2015 | 2006 Buick LaCrosse
I have a 2003 Cadillac CTS. It continues to go into reduced power mode. How do I correct that.
Are you getting a ENGINE POWER REDUCED message ? Is the check engine light on ?
Reduced Engine Power Mode
electronic throttle control .
When the ECM detects a condition with the TAC system the ECM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
Limited torque
Limited range of throttle movement
Engine OFF
Your going to need to take this to a ASE certified repair shop or the dealer , you probably don't have the diagnostic tools to trouble shoot this problem.
https://youtu.be/oPPLAHSSluw
Aug 16, 2015 | Cadillac Cars & Trucks
On my 2010 Silverado the message center says engine power reduced, service stabilitrack and service traction control system. What would cause these messages. It started after sitting for a few days
The fault codes have nothing to do with it sitting for a few days. There are sensors that work with your ABS brakes and TCS to help your car maintain control when corning briskly under load. You probably have a bad sensor on one of the wheels. Recommend you get the Haynes manual to see exactly how to test and replace them. A multimeter will help too.
Apr 04, 2015 | 2010 Chevrolet Silverado
Throttle position sensor 06 grandprix gt
O2 sensors can cause this and often they clear up after a good run.
Nov 20, 2013 | 2006 Pontiac Grand Prix
Hi I have 2000 BMW 528i, It all started with Brake oil, I put wrong one Dot3 and realize it is DOT 4 for BMW and bleaded out what ever was there and put New Brake oil. removed air from all 4 sections on...
Eml is the throttle fault light for the electronic throttle control you will need to get the fault codes read to find out which end the problem or problems are at on the throttle control
Asc is the traction control and when wheel spin is detected it shuts the butterfly on the one throttle body until the wheel spin is reduced get the actuator in the wheel well checked for damage to the wiring to the throttle body
Mar 16, 2017 | Cars & Trucks
Tow messages appear on the dash board: Service traction control and Engine power reduced. When this happen I can feel the shift in the transmission when I'm driving. After a while these messages d
Pretty much tells you the system with the fault
Traction Control is embedded into the abs braking
system, so diagnose that using the codes you have,
same as any other obd codes you get
The Reduced Power could be another problem & it
cuts off fuel injectors to save the exhaust converter
from overheating & being ruined
Mar 10, 2013 | 2009 Chevrolet Impala
Reduced engine power on
The traction control uses the speed sensor in the transmission and the wheel speed sensors to determine wheel spin. If a wheel spins braking is applied to it so that the power can be transferred to the other wheels. At some point the ECU detected a gross disagreement between the sensors and so as a precaution has entered into a limp home mode. On some systems if the fault is in error it can be cleared by putting the car into drive and moving forward a meter, putting in reverse and going a back a meter and doing this three times. If one or other of the sensors are faulty this process will not allow the error to be cleared. You need to check or have checked the error codes and the speed sensors.
May 28, 2010 | 2007 Chevrolet Impala LS Sedan New Cars
Liquid Performance Premium Brake & Parts Contact Cleaner - 14oz Logo
41 people viewed this question
Top liquidperformance Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a liquidperformance Vehicle Part and Accessory Expert? Answer questions, earn points and help others
