Printer cannot find home
How do I reset printer
How do i fix a home network that was hacked? now i can;t see my printer any more. the printer is a mfc7840w by brother.
You will probably have to reset the printer to have it access your network. If you put a new password in, your printer and anything else that accesses your network (like a TV) will have to be reset. Just run the network wizard and follow the instructions.
Oct 01, 2014 | Office Equipment & Supplies
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
  • if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
  • Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
  • Press the Home button to return to the main menu.
  • Open the front cover of the printer (to access cartridges).
  • With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
  • The reset menu will now appear on the LCD display.
  • Scroll through the menu to select a color and yield to reset.
  • The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Oct 26, 2013 | Brother MFC Office Equipment & Supplies
My printer displays E 2 7 that the "printer absorber is full"
There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Use a reset procedure to clear the error in your printer and start printing again.
1. Turn off the printer
2. Press and Hold both the Power and Reset button for 10 sec
3. While Holding the Power button, release the Reset button
4. Press the Reset button twice then release the Power button
5. Wait until the printer display " 0 " (or RESTART) on the led screen
7. Press Reset button 4x
8. Press Power button 3x and wait for printer to power off
9. Press the Power to turn on the printer
Do this as many times if the first attempt didn't work until it fully reset.
Aug 25, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Install the correct print head
You can clear the errors in your printer in three reset procedures.
Reset it manually
2. Press and hold the Resume Button, an indicator light green
3. Press and hold the Power button
4. While holding the Power button, release the Resume button
5. While holding the Power button, press the Resume button twice
6. Release the Power button
7. Press the Resume buttons four times
8. Press the Power button to confirm the operation
9. Turn off the printer
Reset canon mp600 to factory setting (if the first procedure did not work)
1. Press the Home button
2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press OK button.
4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset Settings, then press the OK button.
5. Use the Easy-Scroll Wheel or the up/down arrow to select Yes on the confirmation screen and then press OK
6. Press the HOME button to return to the Home Menu
Final reset (If errors did not clear and or another error appears this will clear it)
1. Press and Hold the Resume button and wait until the printer self restart.
2. Release the Resume button when the printer restart
3. Wait until the printer fully initialize and try printing again.
That will solve it.
Please comeback and give some ratings.
thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Ink absorber (sponge part)
Mp Tools are utilities designed to clear errors that will appear in an MP150 printer. Download this MP Tools here.
2.
Happy printing.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My printer canon pixma mp 150, the tank is full..what should i do
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Aug 11, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Lost ip/connection on Dell 1720dn
try resetting the "print spooler"
  1. start
  2. control panel
  3. admin. tools
  4. computer management
  5. services and applications
  6. services
  7. scroll down till you see "print spooler"
  8. left click once
  9. "restart"
Jan 06, 2010 | Dell 1720dn Laser Printer
Parts inside your printer are at the end of their
On your machine it means that the ink absorbers are full. There are around 9 of them. You will need a shop to replace them and then reset the counters.
Aug 10, 2009 | Epson Stylus Photo R320 InkJet Printer
43 people viewed this question
k24674
jasbo
jasbo
