Arrow T50P ARROW STAPLE GUN Logo
A
Anonymous Posted on Apr 03, 2015
How can i load 9/16 staples - Arrow T50P ARROW STAPLE GUN
My gun will not shoot staples
The most common cause of the gun not firing is loading it with the wrong staples. Look at the packaging for the staples and see if it lists the gun. Staples are NOT universal and are make for specific staple guns.
It "sounds like" it is jammed. You may have to pull out the staple with needle nosed pliers. e`1
How to Load Staple Gun
How to Troubleshoot Staple Gun Hunker
How to load staples
Staples newly purchased will always be attached when purchased and that answers your question...wherever the device u are loading has a horizontal channel, there will be a loading window at the end. Take it apart by realeasing the cap or spring at the bottom and sliding the train of staples into the channel inside. Replace cap or spring lever to original position and secure. Stapler is now loaded.
How do i open the stanley tr110 staple gun to load the staples
Angelbabie...Like most things, it's pretty easy if you know how.
1.Release the loading latch located on the back end of the staple gun by pinching it with your thumb in a downward motion. This will release the catch and allow you to pull the loading slide out.
2.Hold the gun upside down (so the staple don't fall out) and place a stick of staples in the bottom of the channel which will be exposed once you pull back the loading slide.
3.Push the slide back in and make sure the latch is engaged. All good to go!
Happy stapling.
Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
6helpful
How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
2answers
Can't load staples
Fire the stapler with the load chamber open and down, see if anything falls out. Point it in different positions and fire it, just make sure it cannot fire anything at you.
44helpful
3answers
LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
8helpful
Staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Top Arrow Tools & Hardware - Others Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
