Question about Arrow STAPLE 9/16"T-50 1250PK
How do i load 9/16" staples into my arrow t50p gun?
I cannot get the staples into the magazine
2 Suggested Answers
  • 623 Answers
SOURCE: I cannot figure out how to load an Arrow T50P
Turn it upside down. On the end opposite where the staple comes out look for a tab on each side you squeeze to release the staple holder, the staples go in to this holder upside down as well, just push it back in until the releases catch and hold it in. Hope this helps.
Posted on Jun 21, 2010
T50 elite wont staple
I just bought a T50 elite, and it will NOT staple too.
Simple 3/8" staples loaded and nothing comes out.
Jan 31, 2012 | Arrow T50P ARROW STAPLE GUN
How to load staples?
    • 1 Push in the push rod plate on the back of the Arrow T50P and press down to unclip the push rod from the gun. Pull the push rod out of the staple channel and away from the staple gun.
    • 2 Insert a strip of staples into the channel with the tips of the staples pointing toward the bottom of the staple gun.
    • 3 Place the end of the push rod into the staple channel of the gun. The end of the push rod has a small, solid piece of metal that fits into the staple channel.
    • 4 Press the rod all the way into the staple gun until the rod plate engages in the notch at the rear of the gun.
Jun 26, 2011 | Arrow T50P ARROW STAPLE GUN
I loaded the stapler as described above. Now I hear the staples sliding around inside the casing. I loaded as many staples as the gun will hold. I pressed the handle down and three staples came out at...
You need to load just enough staples in it that when you put retaining spring and clip back in that it will let catch on back of spring to go into slot in frame. I hope this helps. Thank you
Nov 19, 2010 | Arrow T50P ARROW STAPLE GUN
I cannot figure out how to load an Arrow T50P staple gun
Jun 17, 2010 | Arrow T50P ARROW STAPLE GUN
Arrow T50P gun jammed - how do you unjam it?
Buu a different brand or model this one is junk and should be taken off the shelf
Feb 06, 2010 | Arrow T50P ARROW STAPLE GUN
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
My T50M Staple strips break up in the gun and jam after 4-5 staples. This happens with old staples (10+ years) and with new staples that were purchased two days ago. Out of frustration I purchased a new...
The staples are held together with an epoxy. I have used staples that are older than 10 years. The problem is the gun. Check for dirt or a burk in the magazine as well as a bent pusher blade. My gun also had a problem loosing a screw and nut that attached at the blade guide.
Jun 12, 2009 | Arrow T50P ARROW STAPLE GUN
Piece of staple stuck in the trigger section of arrow t-50p
First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
Jan 11, 2009 | Arrow T50P ARROW STAPLE GUN
Arrow STAPLE 9/16"T-50 1250PK Logo
538 people viewed this question
Top Arrow Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you an Arrow Craft and Hobby Expert? Answer questions, earn points and help others
