Question about Dyson DC31 Animal Bagless Handheld Cyclonic Vacuum
What telescopic extension tube do I need? - Dyson DC31 Animal Bagless Handheld Cyclonic Vacuum
How to put the telescoping wand back and use DC25 vacuum again as regular?
Carefully put metal tube back into the hose so that the hose is on the outside of the tube Make sure that it is the correct way around when fully returned i.e. that the handle part is the right way.
Aug 16, 2014 | Dyson DC25 Bagless Upright Vacuum
Telescopic extension tube has lost clips
This can easily be repaired by ordering the ***.kit locking devise, not kidding on the name; part # 03876673.
Jan 12, 2012 | Miele S7210 Bagged Upright Vacuum
How do I remove the extension from the machine?
For information on using the quick-release Telescope Reach wand, please see our online support page:
http://www.dyson.co.uk/support/help.asp?article=709&product=DC14-ANIMAL
If you need any further information or assistance, please get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US) - one of our experts will be happy to provide the advice you're looking for.
Kind regards,
Jack
Dyson Online Customer Support
Sep 10, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Is there an extension hose available for dyson dc 25
Unfortunately we do not currently manufacture an extension hose compatible with DC25. The Quick-draw Telescope Reach wand supplied with the cleaner stretches to 4.4m (16ft), to reach to the top of an average staircase.
However, you may wish to visit www.dyson.com and click on 'Accessories' to view our full range of compatible dusting tools. Designed by the same engineers as the cleaners themselves, the tools are designed to remove dirt and pet hair from a wide range of floor surfaces, upholstery and the stairs.
I hope you find this information useful - if you have any further queries, please get in touch with us directly on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the information and assistance you need.
Kind regards,
Jack
Sep 02, 2011 | Dyson DC25 All Floors Bagless Upright...
My extension tubes were put in incorrectly and I can;t unstick them. Suction is not great think something is stuck in tube.
Hello There! I had the same exact problem. Seems something was wrong or stuck in the tubes.
Finally, when I kept trying to clean it out, the tube ripped off and I found a clog of dust in it. So, try getting replacement tubes & it'll work for sure!
I wish I helped you! Let me know if you need anymore help! Don't forget to rate! :)
Jan 14, 2011 | Kenmore 25614 / 25615 Progressive Bagged...
I NEED A TELESCOPIC HOSE FOR MY PHILIPS EXPRESSION HOOVER, WHERE CAN I GET THIS MY HOSE PIPE IS BROKEN AND I HAVE TRIED TO GET A NEW ONE AT VARIOUS SHOPS HERE IN IRELAND AND I CANT.
Hi - greetings from Scotland! Im not sure if you mean telescopic hose = do you mean telescopic metal tubes? If so they are readily available on ebay.co.uk I buy from many sellers on there but Hoovermania are one of the best.
What you need to do before order is to measure one of the smaller cleaning tools at the opening with a ruler where you'd usually put the hose. If you haven't got one to hand measure the end part of the plastic handle where the hose is where you'd usually attach the pipes. Generally if it measures 3.5 cm this works out to be a 32mm fitting tube which is readily available on Ebay and from different sellers. If however it is more then it has a 35mm fitting.
If its bigger than that, then you'd need 35mm tubes of which some are still available on EBay. In any case, you can look at different manufactures because when it comes to telescopic metal tubes the 32mm fittings will fit any vacuum cleaner that can accomodate these sizes. Therefore shop around; Hoovermania have a few on offer and you can phone / email them if you are not sure.
Mar 27, 2009 | Philips Vacuums
Wand
Do you have a telescopic/height adjustable wand or just two tubes which have to be stuck together? If they are made of plastic well, it may well be broken. If its metal check that the tops aren't corroded or the handle itself isn't broken. If the tubes/wand isn't sliding up and down (i.e. if its height adjustable) then something has got stuck. Sadly for this kind of repair you'd be better off to buy replacement wands or consider something aftermarket on EBAY. Check the diameter of the tubes with a ruler. If it is 3.2cm (32mm) or 3.5cm (35mm) you can buy replacement tubes. If you can't afford that then try furniture polish on a J cloth or similar and with a stick wedge it inside the tube/wand so that it adds a little lubrication or simply a clog - it sounds like there is dirt clogged in the part that slides. Dont forget to rate, thanks.
Jul 26, 2008 | Vacuums
Dyson DC31 Animal Bagless Handheld Cyclonic Vacuum Logo
42 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
