Question about Innovative Technology ITRR501 Audio Shelf System
How to open stuck CD tray - Innovative Technology ITRR501 Audio Shelf System
  • 285 Answers
Most CD players have a small hole in the front bezel, below the disc tray door. If you straighten a large paperclip and push it straight into this hole, about 1.5 inches, the door should pop open enough for you to pull it completely open with your fingers.
It may take a couple of tries, as you need to hit a small metal tab directly inside the hole, about 1/4 to 1/2 inch in.
Posted on Aug 31, 2015
Cd drawers won't open, may have cd stuck in #1 slot
How to Fix a stuck CD Tray - YouTube
? 6:24
https://www.youtube.com/watch?v=gpvjqATX3Rs
Mar 24, 2010 - Uploaded by Guy Techie
Pin won't open my tray :( Help please?. Read more ... I was lucky to find a rubber band in my junk drawer and it ...
When a CD or DVD is stuck or the drive won't open ' PCWorld
Dec 09, 2015 | Audio Players & Recorders
The CD is stuck in the CD burner and I can't get it to open up to get it out
there is a very small hole in under the tray near the eject botton. u can use tiny pins to push in there to open the cd tray. its called emergency tray opener
Jun 01, 2011 | Toshiba Computers & Internet
Hi my problem is with the dvd tray it does not open . it make a funny noise but it does not open thx
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from connectors on board. Take face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Jan 31, 2011 | Panasonic SC-PT660 Theater System
I bought the cd changer with my unit & two cds are stuck in it. This happened the third time I used the unit.
this is a mechanism problem. Also, maybe something might have hooked the cd tray and made it stuck.
What you have to do now is to open the player by unscrewing the cover, so that you can gain access to the mechanism inside the player.
After you must have opened the cover, plug the cd changer to light, power it on and use you hand to pull out the tray while you press open button.
Also make observations on the disc tray while you press the open button and check the disc tray and look for what is making it stuck and refuse to open. This is why you need use your hand to support the disc tray by pushing it open from the inside.
I wish you good luck.
Feb 25, 2010 | Bose Wave Radio
I cant open my cd tray on my tascam dp01
Look on the front of the CD tray for a little hole... push the end of a paper clip in the hole and the tray should open.
Dec 12, 2009 | Tascam DP01 All-In-One Recording Package...
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
CD is stuck in my bose lifestyle system, the message displays as "opening" but does not open
Not familiar with this model but all cd tray's have a manual release mechanism, its usually a small hole on the front of the tray. I've found a paper clip unwound usually works fine. Push it in the small hole, you will feel it stop against something, push a little harder and the tray should open enough for you to manually pull it open.
Jan 24, 2009 | Audio Players & Recorders
Sonycmthpx9
if under warranty, send for repair.
No warranty, open it yourself and try to open the cd tray/door. remove anything stuck between the tray/door or wriggle the tray/door.
Aug 23, 2008 | Sony Audio Players & Recorders
You did not under stand
If you are able to remove the cd drive form the laptop on top there are 3 very small screws remove those and then you can remove the stuck cd
Aug 03, 2008 | Toshiba Satellite A45-S150 Notebook
CD tray stuck
Problem is very simple, Switch off system, unplug from mains. Open the Cover panel, and remoove CD. Close machine. Plug into mains. Open Tray, put in anothrer CD, enjoy your music.
Mar 05, 2007 | JBL Harmony Shelf System
Innovative Technology ITRR501 Audio Shelf System Logo
217 people viewed this question
Top Innovative Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Innovative Audio Player and Recorder Expert? Answer questions, earn points and help others
