Question about Garden
Starts but won't stay on? Replaced plug, burned off assestor, turned throttle screw checked fuel lines and filters
  • Amy Nicholson
    Amy Nicholson Apr 03, 2015
    to clean the carb, is that something we can do ourselves?
  • Eugene Rounds Apr 03, 2015
    Not so hard if you have an ultrasonic cleaner; otherwise, depending the exact equipment it is sometimes just as cost effective to replace the carburetor.
  • 1,169 Answers
Sounds like the carburetor is needing cleaning and rebuilding. Once rebuilt then the fuel mixture needs resetting if the carburetor has these adjustments.
The diaphragms harden over time and the internal filter clogs. The internal filter screen that both Walbro and Zama using now tends to clogs rather easily but the replacement version in the kits doesn't.
Posted on Apr 03, 2015
Rough idle, bogs when I give it throttle then dies
Brad:
Go back to the carburetor adjustment screws and snug them down gently. Do not use force on those screws or you'll damage the needle valve seats. Turn both screws out one and a quarter turns out and start the saw. The motor should stay running.... if not adjust the screws until it stays running. Turn one screw in until you hear the motor start to stall, then turn that screw out just a little bit. turn the other screw in until the saw starts to stall, then turn that screw out a little bit. Now if the saw bogs at full throttle, turn one screw out one quarter turn. See if the saw runs at full throttle... if not turn that same screw in to where it was and try the other screw the same way. If you're good, you can adjust the screw while the saw is running to get the best full throttle run. This is not an exact science, and it takes time and many adjustments to get the saw to idle and run at full throttle. Good luck... and have patience.
Oct 03, 2015 | Garden
Vf750 honda idles but dies when throttle opened
Hi, Anonymous and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starts choke but dies with little throttle
1984 VF700 Magna starts but won take throttle
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1995 VF750C Magna Owner Manual
Jun 14, 2014 | 1995 Honda VF 750 C Magna
Why motorcycle starts but only stays running when I open throttle?
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
http://www.motorcycleforum.com/59-motorcycle-repair/109746-only-runs-when-choke.html
Bike starts up idles on choke dies with choke off our when warm
Yamaha XVS13AWC Service Manual
OEM parts for Yamaha
Yamaha XVS13AW Owner Manual
May 06, 2014 | 2008 Yamaha V Star 1300 Tourer
2001 Shadow Sabre, Won't idle with choke off unless giving it some throttle.
Hi, Rickgilbreat and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Starts but won stay running unless with choke Discussion
Won idle without choke
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Aug 23, 2012 | 2001 Honda VT 1100 C2 Shadow Sabre
Toro model #51932 won't idle, runs fine above idle
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ==
Jan 09, 2012 | Toro Garden
Won't start fuel pump replaced new tank and relay have fuel after fuel filter runs if I put fuel down throttle body. this is on a4,3.
Nephew had similar problem on different vehicle - had spark to plugs, limited gas, everthing else checked. I did one thing first - check for two fuel filters - one in the tank was only screens and one in the line itself. Found a little in line filter just outside of engine compartment under car next to frame that looked like it had never been changed - partially clogged - replaced it.Almost ran but would not keep running. I had rotor and cap pulled - found that the screw holding rotor in place was loose. The rotor edge next to plug wire leads was chopped up and the cap's plug wire leads were heavily oxidized. Replaced them and got it running but a little rough. Pulled the spark plugs and found gaps from 25 - 100 ---replaced the plugs with correct gapping and it ran really well.
Aug 25, 2011 | 1991 GMC S-15 Jimmy
Honda Shadow VT750 will not idle without choke on
Hi, Epperson2420 and the usual suspects are:
Need Help Bike won run choke in
Honda 1998 VT750C Service Manual
Honda VT750C Owner Manual
May 01, 2011 | Honda VT 750 CD Shadow A.C.E. Deluxe...
I have a 1980 poulan 4200, starts and runs, but no power and 'chugging' when throttled. replaced fuel line, rebuilt carb, no exhaust obstructions, compression is okay ~130psi what's next? Dan
Air cleaner may be plugged. This sounds like too much fuel going into the engine. When you serviced the carburetor, did you replace the diaphragm in the lower chamber and check the needle valve that the diaphragm operates? Did you clean or replace the fuel filter in the tank? If everything has been taken care of, turn both jet screws CW to stops (lightly), then back each out CCW 1-1/2 turns. Start the engine and allow to warm up. Pull the throttle full on, and turn H jet needle CW until the engine starts to speed up. Proper final adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW so that the engine idles fairly well, but will allow the engine to 'follow the throttle'. Adjust idle speed screw so that the engine continues to run, but the chain does not try to turn. Hope this helps!
Nov 04, 2010 | Garden
I need to know all screw adjustments for carb the T L and H settings.
Make sure the fuel filter, air filter, and muffler are not plugged. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Turn both jet screws CW to stops (lightly), then back out each 1-1/2 turns CCW. This is a basic setting and should allow the engine to start and run. Start it and allow to warm up, then pull the throttle full on and turn the H jet screw CW until the engine starts to speed up, but continues to 4-stroke. Correct adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run.. Hope this helps!
Aug 15, 2010 | Garden
Saw starts then dies. Changed fuel ine soaked carb
Check the fuel filter, air cleaner and muffler for plugging. Was the carburetor disassembled when soaked and did you use compressed air to blow out all passages? If the carburetor jet screws have been moved, preset them as follows: Turn both H and L screws CW to stops (lightly), then back out CCW each screw 1-1/2 turns. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine speeds up somewhat but 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that chain stops turning, but the engine continues to run. Hope this helps!
Mar 30, 2010 | Garden
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
