Question about HP Q1251A Designjet 5500 Rtl Dye 42, Printer 6 Ink Color Cmykcm, 128 M
Error system 0b0004 00000011 - HP Q1251A Designjet 5500 Rtl Dye 42, Printer 6 Ink Color Cmykcm, 128 M
Startup 6 beeps
Probable Causes
Error
Beep Codes
Defective system board.
Memory refresh failure.
Faulty DIMM or defective system board.
Error occurred in first 64 KB of main memory.
Faulty DIMM.
Read or write error occurred in first 64 KB of main memory.
Timer on system board malfunctioned.
Defective microprocesor.
Microprocessor error.
5
Gate A20 failure.
6
Defective microprocessor.
Microprocessor-execption interrupt error.
7
Missing or faulty video adapter.
Video memory read/write error.
8
Corrupted system BIOS program or defective system BIOS chip.
ROM checksum value does not match value encoded in system BIOS.
9
NVRAM shutdown register read/write error.
10
Defective microprocessor or cache card.
Cache memory error.
11
Faulty video adapter.
Video adapter failure.
12
Loose video cable connection or defective video cable.Faulty video adapter.
No monitor connected.
13
May 15, 2013 | Samsung NP-148 NP-150 N148 N150 N128 N145...
Long beep at startup
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Dell Inspiron 1018 Notebook
My computer has a critical error on the adress 0x3BC3, how do i solv it?
It might be a fake error message. Use this code 754-896-324-589-742 to unlock your computer. More information about this infections:
http://deletemalware.blogspot.com/2011/07/system-process-at-address-0x3bc3-have.html
Jun 26, 2011 | ASUS Eee PC 901 20G Notebook
Sir, there is an error i.e system error e225 in my canon mf 4350d machine please help me shut out this problem
Sir, there is an error i.e system error e225 in display my canon mf 4350d machine please help me shut out this problem
Apr 11, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
What is this error mean that i get during boot up? 312.198 Eth0:(185488) System Error Occurred (0) 312.199 Eth0:(185489) System Error Occurred (0) 312.200 Eth0:(185490) System Error Occurred...
I think this is related to to the NIC (Ethernet port).
Go into the BIOS and set it to default settings, see if that resolves the problem.
Let me know how you get on.
Regards.
Jun 30, 2010 | MSI P4MAM2-V Motherboard
Please help me ??? system error
System Error: 04Cxxx
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Press ENTER and switch the printer OFF. Remove the Hard Disk
Drive (if installed) and make sure that the EIO card is installed
correctly by pushing it firmly inwards and checking that the two
installation screws are completely tightened. Switch the printer
ON again. If this error code continues to appear then replace the
EIO card.
n If this Error Code disappeared after removing the Hard Disk
Drive, then switch the Printer OFF and reinstall the Hard Disk
Drive, making sure that the two installation screws are
completely tightened. Switch the Printer ON again. If this Error
Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
n If this system error continues to appear after replacing the EIO
card or the Hard Disk Drive, then replace the Electronics Module
System Error: 0000D8 XXXXXXXX (Non-Continuable)
Problem
Description:
External Library Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you.
Apr 06, 2009 | HP DesignJet 1050c InkJet Printer
SYSTEM ERROR - E007 SOLUTION 3
when i switch on the machine, it show a red light with the word system error E007
Aug 09, 2008 | Creative Labs Zen Nano Plus MP3 Player
HP Q1251A Designjet 5500 Rtl Dye 42, Printer 6 Ink Color Cmykcm, 128 M Logo
120 people viewed this question
Seeker5211
Seeker5211
