Question about Home
Pump won't connect to remote - Home
I've got an 03 galant Ls with th 2.4 liter
pump could be in a crooked binding kinking fuel pump sock restricting fuel flow or your fuel pump electrical harness disconnected or has poor connection not seat all the way in pump electrical terminal socket.
Apr 22, 2013 | Cars & Trucks
My heater fan won't work when car remotely started with Bulldog remote starter
The yellow wire at the ignition switch is not connected to the remote start system. Once it is connected to the accessory output of the remote start, it should work properly.
Jan 08, 2013 | Remote Starter with Keyless Entry
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Kenmore 407 50 pint dehumidifier won't drain through hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Oct 13, 2012 | Kenmore 90701 70 Pint Dehumidifier With...
2005 G6 remote . lock won't work but unlock does. Does not seem to be battery. Maybe the connection inside ?
Knowing the poor quality of this remote I would buy another remote on eBay and that will likely solve the problem. Here is a link to an eBay auction. Just $17.99 and free shipping.
Oct 10, 2012 | 2005 Pontiac G6
I installed prostart remote starter in 2002 Sonoma,used xpresskit bypass module to bypass passlock 2, truck started with remote ,now won;t start with remote,have to reset and start with truck key
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground.
Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
Oct 01, 2012 | Vehicle Parts & Accessories
1999 nissan altima won't start,no spark in distributor to the spark plugs..is it because of the security system? Don't have the remote for it..
1. Ignition Switch: Improperly Connected or Faulty Ignition Switch.
2. Battery: Battery Discharged or Faulty or Coroded, Broken, Shorted or Poorly Connected Battery Cable.
3. Solenoid Switch: Starter Solenoid Switch Faulty.
4. Starter Starter Motor Faulty.
5. Wireset: Worn or Damaged Spark Plug Wires.
6. Coil -Ignition-: Faulty Ignition Coil.
7. Distributor Cap: Loose, Cracked or Worn Distributor Cap.
8. Spark Plug: Incorrectly Gapped or Fouled Spark Plug(s).
9. Distributor Cap and Rotor Kit: Loose, Cracked or Worn Distributor Cap.
10. Carburetor: Worn, Faulty or Damaged Carburetor.
11. Fuel Pump Faulty Fuel Pump.
Sep 06, 2012 | 1998 Toyota RAV4
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
1999 tahoe, was running rough, I changed the plugs,that didn't help. Then for no reason it ran like new, then is was stalling and wouldn't rev up, Then it wouldn't start at all. I noticed no...
now that leg won't lite up and the fuel pump won't work ????? The PCM - engine computer supply's B+ voltage to control the fuel pump by energizing the relay .
GM Fuel Pump Relay Testing
Jun 05, 2017 | Chevrolet 1500 Cars & Trucks
Keyless remote will not unlock doors. Door was unlocked with key. Car will not start and the key will not release from ignition switch. Is this the anti-theft and haw do I reset it?
Check the car battery there is a battery in the remote as well but its to new to need to be replaced and so is the battery in the car It sounds most likely like there is a bad connection on one of the battery terminals on the cars battery if the bat is dead in the car the remote won;t work and if the bat is dead in the remote it won;t work but the car will hope this helps
Nov 11, 2010 | 2009 Chevrolet Equinox
Home Logo
65 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
