When I put the cycle of dark garments which I use all the time it doesn't seems to spin as well as it used to I'm having to respin the load once the cycle has finished
  • Washing Mach... Master
  • 5,323 Answers
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Posted on Apr 03, 2015
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
Oct 06, 2014 | Samsung SW62ASP Top Load Washer
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
When I go and try to run the cleaning cycle, the machine will start to spin, then puts no water in and after about a minute en rL error is display. Some time the clean cycle will start with out a problem...
"rL" indicates a garment has been detected inside the wash tub. Garments are detected by weight. The wash tub must remain empty during a Clean Cycle. If you inspect the wash tub and it appears to be clear, inspect the area around the door bellow (rubber door seal) for loose items. It is common for small garments, such as socks and underwear to get lodged in the rubber folds. Pull back the folds around the door and inspect the perimeter of the seal. If you need further guidance please let me know. I hope this helps you.
Jul 26, 2011 | Kenmore HE2 Plus Front Load Washer
Wt you mean by spin in washing machine
its a separate cycle all by itself.
Say U hand wash something in a sink and instead of wringing it out by hand U can put it in the washer and press this SPIN cycle.
So U can also use it to spin more water out of your garments after the regular wash and spin cycle.
Slower spin speeds mean -
  • Cheaper washing machines
  • Quieter washing machines
  • More stable washing machines
  • Longer lasting washing machines because there's less wear and tear on the bearings, motor, carbon brushes, suspension etc.*
  • Gentler on laundry
  • The drum spins for approx 4 or 5 mins. No water is added and you dont add detergent or fabric softener for the spin only option. The object of the exercise is to centrifugally remove excess water from the garments in the drum. They will still be damp but not sopping wet after the spin cycle
  • Spin takes the water out, extract is even better
May 17, 2011 | Frigidaire ATF6000ES Front Load Washer
My washer is making a clicking sound when it is about to begin the high spin cycle to spin the water out of the clothes and is unable to begin the spin cycle on it's own. I have to manually move the knob...
If this is a belt drive unit it could be the belt or whats called a actuator also call a shifter. This componet switches the gearbox from agitate during wash to Spin to extract the water from the garments.
Happy Holidays
Nov 21, 2017 | Whirlpool LSQ9500L Top Load Washer
Dark stains occuring in a pattern of dots on garments (pattern
operate one quick cycle with not load with hot water and detergent to clean the drum
Mar 18, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Control Lock
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clothes too wet
Watch the washing machine go through its complete spin cycle.(It could have a filter in the pump,check for water flow coming out of the drain. Make sure the washing machine is fully leveled with a square. make sure you put fairly big loads to keep it balanced. If the washing comes out wet on the final spin ,add some more garments and then put it on spin again as the w/m might be going out of balance. Under the work bench on top some times there is a spring to adjust the tension. about every five or six years the motor brushes need changing.
Jan 04, 2007 | Bosch WFL 2463 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
