Wont power up
There is no power when switched on
PRECOR C956 power switch wont stay on
The power switch on Precor treads is also a circuit breaker. If it trips when plugged in, you have a dead short in the machine.
Feb 06, 2014 | Precor Exercise & Fitness
Lights wont turn on a 99 silverado
Did you check for power in and out of the headlight switch ?
You should have power on the red and orange wires going into the switch and yellow going out to the dimmer switch.
Feb 06, 2013 | 1999 Chevrolet Silverado 1500
Toshiba l40 wont switch on
Open the Control Panel, Power settings, Advanced Power setting, Change Sleep to Never, Hibernate to Never, set to High Performance. Shut down, unplug when not in use. Remove battery if use a lot on AC.
Dec 26, 2012 | Computers & Internet
No acc power after replacing ignition switch/wont turn over
I think ur fuse short, check all the main fuses
May 12, 2010 | 1984 Chevrolet Camaro
Power windows and power locks wont work
Check your fuses first. Then check for power at the switches, and power from the switches to the respective solenoid and motor. Most likely it's fuses. Also check where the wiring runs through the door into the car for bare spots in the wiring that might have blown the fuses.
Jan 21, 2010 | 2004 Mitsubishi Endeavor
My sandisk mp3 is frosen on the meau and wont trun
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Oct 01, 2009 | SanDisk Sansa e250 MP3 Player
Pc wont power up
Is there an on off switch on the back out the computer next to the main power socket? If so move it to the on position.
Check the mains lead and make sure it is firmly inserted in the socket.
When you press the front panel on button and it doosn't boot up and there is no light indicating power, then you have a faulty switch mode power supply.
Remove the switch mode power supply and replace it with a new one with the same wattage or greater wattage.
May 07, 2009 | eMachines D3415 PC Desktop
My power switch flashing yello and wont power on
Try another powersupply, normarlly faulty powersupplies can cause problem similar to this one.
Jun 25, 2008 | Dell OptiPlex GX150 SF PC Desktop
669 people viewed this question
 Grubhead
Grubhead
