Question about ASUS Tablets & eReaders
Oh please please help. Can't get demo mode off my new Asus memo 7. Have tried all the suggestions but no luck. How is this happening to so many :( Viv
    Top Expert:
  • ASUS Master
  • 43,003 Answers
Assuming only many do not read the instructions before doing a lot of button jabbing . I also have been guilty of that .and then there or those that do not understand the gadgets but get them just because someone else has one then there those that get one given to them and they do not want to learn how to use them period , (like my wife).
Posted on Apr 28, 2015
4 Suggested Answers
  • 69 Answers
SOURCE: My new Asus memo hd 7 will not turn on whatsoever.
Remove the rear cover...use your fingernails, or something thin and plastic (like a guitar pick) to get it started, then work your way around unsnapping it until it is off. Now unplug the battery, the battery connector pulls up towards you to unplug, it snaps in. Now, you have to put the rear cover back on..because as you will notice there is foil on it, and pins on the board that ground through that foil. After the cover is back on...press and hold the power button for 30 seconds or so to completely discharge the energy from the board. pop the back cover off, plug the battery back in, put the cover back on...and plug the tablet in. Now when you push the power button you should see a battery charging icon...let the tablet charge for an hour or so...then boot it up if you would like, but let it charge to 100% before unplugging. Good luck!!
Posted on Feb 15, 2014
BaronVonNuke
  • 1915 Answers
SOURCE: My ASUS memo pad 7 is brand new out of the box wont turn on or charge.
If this is brand new why waste your time, take it back to your retailer for exchange.
Posted on Dec 26, 2014
  • 752 Answers
SOURCE: How do I access offline books downloaded to my Asus MEMO Pad 7 books from Scribd ?
This depends on what format they are in (epub, mobi, pdf, html, txt or a range of others) You may need a special reader for that format.
I use a library organizer calibre which contains a converter and a viewer which supposedly allows you to convert books between different formats and to read book in a variety of different formats. You must add the book to calibre to be able to read it. It's free. I have a kindle but that only reads mobi formats, and reading epub books atm so calibre works well for that. I have not used any of the "library" functions so far. I found it quite difficult to learn at first.
8.February.2015
Posted on Feb 08, 2015
How do I remove ASUS demo ad @asus .com?
I searched "demo ad removal Asus memoPad" & got a fair number of hits. Have a go and see what you can find.
Jun 16, 2015 | ASUS MeMO Pad 8 ME181C-A1-WH 8-Inch Tablet...
I cracked the screen on my ASUS memo pad 7 and since then it's been turning itself off. Now it won't turn on again
hi yes I think u need a new screen ring an asus dealer ask for a price to repair it if the cost is to high check on ebay they have some good deals ...good luck
Jun 01, 2015 | ASUS Tablets & eReaders
I have bought a new asus memo 7 and i cannot connect it my wifi, it keeps saying authenticating problem
The issue isn't with the tablet, it is something in your Wifi...there are a number of things that it could be, try simply rebooting your router, that would be the easiest thing to try. If that doesn't work, try switching your tablet to "airplane mode" , and then try to connect...
Oct 08, 2014 | ASUS 16GB MeMO Pad 7" Tablet Cherry Pink
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
Jul 20, 2014 | ASUS MeMO Pad HD 7
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
What do you do when memo will not come on?
I called Asus. Told to connect charger & hold volume up & power for 40 seconds. Nothing happened, then press power & volume down. Nothing happened. Then told to hold volume up & power for 60 seconds, and it should come on, which it did.
May 28, 2014 | ASUS MeMO Pad HD 7
Will not update or download anything anymore
you should use Vpn ( such az kerio )
Apr 24, 2014 | ASUS MeMO Pad HD 7
Trying to factory restore a asus memo pad
It not power on or it have a paswoard problem ? if is paswoard remove it with yoo pc and this program mobogenie instal it in you pc then conect and instal you memo pad in the pc then go to folders ask the paawoard archive edit it and ready clear all paswoard in to you memo pad vote please
Dec 07, 2013 | ASUS MeMO Pad HD 7
Turn off demo mode on asus memo pad
If it's the issue we had, that is an asus video clip plays over and over when the tablet isn't used, I found the solution. It's in fact a screesaver! so go to ASUS apps, and click screensaver, and deselect the screensaver check box.
Cheers,
Jeff
Oct 26, 2013 | ASUS MeMo Pad Smart 10
Tablets & eReaders Logo
115 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
