I would go back to make sure that its plugged in correctly. What is your PC doing when you see the Red blinking light on your hard drive? Do you hear any beeps?
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Sorry nothing to do your harddrive is dead. you might be able to open the case and replace the harddrive with a new one. Try searching google or youtube on how to do that.
Regards.
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Hard drives can make a little noise when you shake it gently, but to hear clicking sounds when it's running is not a good sign. I dropped a brand new 120 gig hdd for a customers lap top right outside the store. It made noise when I shook it "carefully" but nothing installed. NOTHING..... Tested it. It was dead. Since you say it's an external see if all inside is connected tightly.
WHEN POWER IS FIRST TURNED ON I HAVE A SOLID RED LIGHT BUT NO PICTURE. THEN YOU HEAR THE TV CLICK OFF. THEN RED LIGHT STARTS TO BLINK IN SET OF (3) TIMES.
Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. Eventually the red indicator light stays red. Tried unpluging set. Is it the EPROM ?
