Question about LG 32LK330 TV
What are the microfarads of the capacitors on the main board?
Ub.cusdlh
  • 693 Answers
This information should be on the side of the capacitors themselves. -Steve
(EDIT)
Now that we know that the capacitors seem to have been glued to the PCB with the required information concealed, great care MUST be taken so as not to damage the board. My next question would be to ask what reason would you have to suspect the capacitor(s) to be faulty? Is there physical damage to the case? I would STRONGLY recommend not using a heat gun to attempt removal of any component from a printed circuit board. The heat these generate is easily enough to lift the copper runs putting you into an entirely new world of hurt. I would suggest desoldering first with a low-power iron (less than 15W) THEN a fine X-acto type blade to work the component free.
Posted on Apr 03, 2015
Testimonial: "ONE WOULD THINK SO AND ASSUMPTIVELY, WE ARE RIGHT; HOWEVER, IF INDEED THAT INFO IS ON THE SIDE, ITS THE SIDE GLUED FIRMLY TO THE PCB ITSELF. UNSOLDERED, I STILL HAVE TO USE A HEAT GUN FOR REMOVAL. DAMAGE TO THE BOARD IS NOT AN OPTION FOR A ASPIRING TECH. I'LL UPDATE WHEN I'VE MADE THE INSTALL."
My rca plasma tv model number 42pa30rq turns but no picture or sound i replaced the main power board and the y board
marcos
here some details or hints!
1) check the inverter video board, if is well connected.
2) check the video board, for any capacitor and microfarads are fine. (this will be made by a tech, and multimeter)
3) some cap is burn in anyplace of the boards. **
Jan 30, 2017 | RCA Televison & Video
What is the service code of LG32LK330
mine is on back of tv 32lk330-UB.CUSDLH
Oct 27, 2012 | LG 32LK330 TV
Maytag dishwasher model MDB7100AWB has power to dishwasher but nothing works (as if there was no power). Is there a fuse in the dishwasher somewhere? If not, what is the most likely cuase? Thanks.
No thier is no fuse so what the most likely problem will be a defectice door switch switch so even though the door is closed the switch thinks its open and will not allow the dishwasher to start.
GENE
Oct 02, 2011 | Maytag MDB7100AWB Dishwasher
My TV is only showing half of the picture only other half is black can u say any solution for it
If you are talking about top and bottom, there is a small integrated circuit on the main board , it is called the vert out put IC. You will need to replace it and the 4.7 microfarad capacitor located right beside it.
Please leave feedback
Feb 21, 2011 | GE 31GT660 TV
I have a polaroid 37 inch flatscreen hd tv...the light for the power comes on but the screen will not come on...sometimes if you leave it on the screen comes on later..there is no sound until the screen...
I did like everyone else has yesterday. I replaced (2) 1000 microfarad/ 10 volt capacitors on the power board with (2) $1.59 1000 microfarad 35v capacitors. I had to take the plastic cover off the back, then remove a metal cover to expose the board. You can follow the wires from the power cord. On my unit they are two small cylinders in the upper right corner of the board. The surfaces facing up were slightly bulging (indicates damage). I have a guy at work who messes with instruments all the time. It took him about 10 minutes. I got the capacitors at radio shack. The 35 volt capacitors are larger than the ones replaced, but fit in the available space, no problem.
Jan 10, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
My Acer AL2017 "flashes" on then off when I hit the power on button. It does it repeatedly. If I cycle power enough times it will eventually remain on.
This is the same issue I had AND....you can fix this by replacing 5 capacitors in the screen Power Board, So here we go: go to Radio Shack or similar store that sells capacitors and buy (3) 220 Microfarad capacitors Radio Shack Part Number 272-1029 and (2) 1000 Microfarad capacitors PN 272-1032. Now on your board you will see the bulging capacitors just remove them and replace them with the new ones. PAY CLOSE ATTENTION to the polarity, there is a negative stripe on the side of the capacitor. Make sure it goes back in the way the old one came out. Now the radio shack capacitors are 35vdc and the stock capacitors are 25vdc and the new capacitors are bigger in diameter but the difference is ok as long as the Microfarads are the same. Mine were replaced and all is well now
Sep 18, 2009 | Acer AL2017 20" LCD Monitor
Acer AL2017 has trouble starting up.
I CAN FIX THIS or rather you can there are a total of 5 capacitors in the screen Power Board, that upon inspection the ends are bulging therefore they are bad. So do this: go to Radio Shack or similar store that sells capacitors and buy (3) 220 Microfarad capacitors Radio Shack Part Number 272-1029 and (2) 1000 Microfarad capacitors PN 272-1032. now on your board you will see the bulging capacitors just remove them and replace them with the new ones. PAY CLOSE ATTENTION to the polarity, there is a negative stripe on the side of the capacitor. Make sure it goes back in the way the old one came out. Now the radio shack capacitors are 35vdc and the stock capacitors are 25vdc and the new capacitors are bigger in diameter but the difference is ok as long as the Microfarads are the same. I preformed this and my monitor works Outstandingly well with NO problems yea I’m a happy camper.
Jun 07, 2009 | Acer AL2017 20" LCD Monitor
Replace main board on LG 42LC7D-UB
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
http://cgi.ebay.com/LG-42LC7D-UB-LCD-CONTROL-BOARD-6870C-0119A_W0QQitemZ150277759127QQcmdZViewItem
Mar 13, 2009 | LG 42LC7D-UB Television
Samsung LTN1565
There should be some kind of thermostat inside of the set that goes bad, but I could never find it and I was told you would have to replace the whole main board which now a days cost more than the whole tv itself.
Sep 08, 2008 | Samsung LTN1565 15 in. HD-Ready LCD...
7 red blinks
Is the light blinking 7 times on front of TV ? If u take the back cover of the TV off you should see two leds on the bottom right of power supply turn on when u push the power button. When the TV go into error protection on the upper left of power supply you should see. A blinking green light. Please inform me of the error it flashes and ill will be able to help further. ( Serveral possiblilties it could be from audio, bad power,and faulty Y-main.)
Apr 28, 2008 | Philips 42PF9630A 42 in. Plasma Television
LG 32LK330 TV Logo
49 people viewed this question
Computer Repairing
Computer Repairing
