How do I fix no display on screen?
I have a china t.v that has no display on screen. flyback cap oscilate and there is no horizontal or vertical issu. 180 voltage on base and heater 5 voltage is ok... picture tube is ok what should I do plz help me fixya team..
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Check whether the heater filament inside the CRT glow or not.
Electro help
Posted on Apr 04, 2015
    Sergeant:
  • 154 Answers
OK I will try a little bit, If we are talking about a glass tube TV then No picture can be a number of things, first is there a tube heater glowing? have we got EHT and Focus (static when tube front touched or crackle on turn on) next thing is are its colour guns Off by some means (blanking circuit).
This will occur in response to a fault mostly, in the main Frame or Field collapse which causes a line mid screen, this will damage a tube so a sets reaction is to clamp off the guns (no picture).
If I determined EHT and Focus volts existed (if not suspect flyback transfomer) my next move would be to naughty and flash the tube with a resistor, A resistor of about 56K or little higher and a wire at one end long enough to reach from its earth to the tube base, with the set on JUST DAB QUICKLY one of that tubes cathodes while looking at its screen via a mirror. Please note this is non technical way but all you need to know is, is there just a line or a single colour screen (yes I know you tech guys but it is a quick way).
If it is a line then you have frame collapse and thats where to look, if its blank then there is a lack of video drive, possibly a IC or in some old sets I worked on their output emitters sat raised via a simple zener of about 7.5v which goes o/c and its tube guns lift to a high voltage then cut off if I remember rightly cathodes would be around 140 to 165v depending on tube size etc but do not quote me.
Now a thought occurs to me has this flyback transformer got control pots on it, one for focus (top one) and a second for G2 (a high voltage for the tube) note its position before you move it, if after flashing that tube you see a picture then this voltage is low (been got at or faulty transformer) if this transformer has three controls then I would get worried as this idea was employed on monitors to enhance their focus and presented an extra high voltage those I did see with tubes blown (internal flashover) because these transformers had failed.
This is enough to start with hope this helps.........
Posted on Apr 03, 2015
No picture, Horizontal line center of screen
Can be a case of vertical collapse. If this is the case, then the vertical oscillator and/or the vertical driver circuit are faulty. .
You can take you problem directly to zenith. They have a customer service post available here
Mar 30, 2008 | Zenith Z32H41D TV
How do I fix red vertical line?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 22, 2015 | LG Televison & Video
Where is horizontal output ic in my t.v?
There is no horizontal oscillator IC. The horizontal oscillation is generated and outputted by the main system control IC LA76810 itself. Refer some circuit diagrams using LA76810 to get more details about the horizontal oscillation output from the IC. Measure the frequency at that output pin. It should be some ever near 15.62KHz.
Type in the IC number, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 31, 2015 | Televison & Video
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
No vertical output, but vertical ic workng fine,vertical supply ok,
Touch the input pin of the vertical IC, by the blade of the screwdriver, and see whether there is a tendency to change with width of the horizontal line on screen. If so, check and replace the horizontal, video if, vertical oscillator jungle IC. Check the frequency to the input of the vertical scan IC, with a frequency meter. If there is frequency, and still no vertical scan output, check the yoke connection, and make sure that it has no open circuit. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 18, 2013 | Televison & Video
No horizondal oscilation.
no line flyback transformer
vertical line horizontal out put circuit
horizontal line vertical output circuit
at fault
Sep 14, 2009 | Televison & Video
Help me to fix the TV
Try to inspect for a loosed connection in the printed circuit board especially in the horizontal circuit. This includes the ic for horizontal oscillator, transistor for horizontal driver, horizontal output transistor and the high voltage section which includes the flyback. Pls. observe safety when dealing with these ciruits coz it deals with high voltage! Good luck!!
Apr 22, 2008 | RCA 27F650T 27" TV
Samsung 591s monitor
It isn't getting a steady, usable source of power, you can try to diagnose this your self but it will be a power issue INSIDE the monitor within the circuit board
Jan 22, 2008 | SAMTRON 55V 15" CRT Monitor
RE:Sanyo 27 " Flat Tube Set
What about a cap in the power supply for the vertical circuit? Usually found near flyback-- 2)check vertical drive signal (comes from jungle IC ).Use your scope....
Sep 26, 2007 | Sanyo DS27910 27" TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
