Question about knittingdaily.com
What does f/b stand for in a pattern - knittingdaily.com
  • 695 Answers
Hi Georgina
It stands for knit front and back.
See the link below and scroll down a bit. You will find a video link for your kfb.
Hope this helps.
-Steve
Knitting Increases KnittingHelp com
Posted on Apr 03, 2015
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
Tip
Perform Nozzle Check Pattern of Canon Inkjet Printer without Computer
Models:
BJC3000 and above,S300 and above, i450 and above,Pixma ip2000 and above
Procedure:
  • Set A4 paper in paper tray.
  • In stand by condition,hold down Resume/Cancel button until LED indicator blinks twice then release the button.
Models:
Pixma ip1200,1300 ,1600,1700,1800,1900,2200
Procedure:
  • Power on the printer, immediately after printer standing by press Resume/Cancel button 5 times within 2 seconds.
The printer start printing nozzle check pattern after procedures above performed properly.
on Dec 02, 2008 | Canon S400 InkJet Printer
What does RS stand for in a pattern (?)
Usually the knit side is the right side, but sometimes the purl side is used for the right side. When this is done it is called reverse St st. When a pattern tells you to work in St st, it means to alternate a knit row with a purl row.
http://www.craftyarncouncil.com/tip_knit.html
What does RS stand for in pattern Google Search
Dec 03, 2016 | knittingdaily.com
English instructions for simplicity pattern 1296
  • Quick Charge 2.0 2port QC2.0+4port USB Charger 5V 9V 12V 60W USB Fast Charger for Mobile Phone, Convenient to Use: with stable stand, compact and portable design for the usb charger.
Chornic Quick Charge 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Dec 01, 2016 | Simplicity Sewing Machines
I have a vizio E422vl and need screws to attach it to a stand anyone know what size screw I would need
Yadayada is wrong, the screws are listed on page 2 of the manual, you need metric. M6 20x1MM
If you need to buy the stand, the pattern is 200x200MM
Sep 27, 2016 | Vizio Televison & Video
What does the abbreviation SKTPO in knitting stands for?
The abbreviation explanations should be included in your pattern instructions. Pattern designers sometimes use different abbreviations so it is best to refer to the included instructions.
This may help:
Patterns Posh Yarn Luxury hand dyed yarns from the UK
Apr 15, 2016 | Sewing Machines
Need instructions for pattern m9888
contact the manufacture of the pattern and ask them for the instructions. I'm hoping the m stands for McCalls
here is a link for customer service
http://mccallpattern.mccall.com/pages/customer_service/94.php
or here is a phone number
(800) 782-0323
Mar 04, 2016 | Sewing Machines
I bought a binks bbr with a tip of 97p . don't know what the 97p stands for. wanted to know if you guys knew this answer. I'am thinking it could be the needle size? your answer will be greatly...
The 97P stands for the Air Cap. For the BINKS BBR (or Mach1A) are more than ten different air caps available which differ in air flow capacity and pattern width. The 97P has an air volume of 21 SCFM (@10 PSI) and a pattern width of 16" (if sprayed from 10" distance).
Michael
Jun 14, 2011 | Binks Spray Gun Bbr Auto Hvlp Auto Recirc
I NEED TO PUT A FIRE WALL OF 5/8" DRYWALL ON THE OUTSIDE OF A NEW FREE STANDING WORKSHOP ON THE SIDE FACING MY EXSITING GARAGE WHAT IS THE BEST WAY - PATTERN-TO APPLY THE DRY WALL TO GET THE PROPER...
any pattern, whether you lay it on it's side or stand it up will provide the same protection
Make sure the rock you buy is fire rated, not just 5/8 standard rock
Feb 06, 2010 | Porter Cable 7800 Drywall Sander With Dust...
knittingdaily.com Logo
56 people viewed this question
Top knittingdaily.com Computers & Internet Experts
Steve
Steve
Andrew Taylor
Andrew Taylor
Are you a knittingdaily.com Computer and Internet Expert? Answer questions, earn points and help others
