Question about Kitchen Appliances - Others
Not heating properly. error code e9
How to fix it ?
buffalonyman
  • 1865 Answers
SOURCE: Oven shows error on control panel: F1:E9.
Replace the electronic range control ERC
Posted on Nov 16, 2009
1stBSP
  • 52 Answers
SOURCE: Error code E9
High pitched noise is from a very high CO2 level. Adjust the gas pressure to stay above 11" w.c. and have a gas technician with a calibrated CO2 analyzer adjust the CO2 levels.
Posted on Jul 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: On Power up the error code E9 displays with a continuous beep
F9 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. You will need to check to following:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
3. Check/Clean Drain Pump Filter of foreign objects
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off
6. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pull a vacuum on it with a shop vac. It could be that you have an obstruction somewhere. You may have to check the drain pump and the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub. This area can get clogged with debris
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the center rear of the washer behind the wash tub). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the air hose is still attached. This is usually a clear or black rubber hose. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. The pressure switch can be checked by removing the the large connector plug from the front of the CCU at the very LEFT. Readings across pins 1 to 2, 3 to 4, 4 to 5, and 4 to 6 should ALL read 0 ohms.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. If the pump is running and clear of foreign matter, the pump is probably not the problem. A meter reading across the pump motor windings at the connector plug should be about 15 ohms.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off (even with the washer turned OFF). You need to ask yourself if you find standing water in the tub when not in use. Replace the water inlet valve if this is the case. Readings across the HOT and/or COLD solenoids should each read about 800 ohms.
5. The suds error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent (which is great, because on the newer models NOT using HE detergent voids your warranty), but HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause over sudsing.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a failed CCU or pressure switch
Posted on Sep 12, 2010
heatman101
  • 43501 Answers
SOURCE: No heat to the dryer.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101]][
Posted on Aug 13, 2011
  • 5245 Answers
SOURCE: E9 error code
Before calling service technician, copy following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Bosch_E9_troubleshooting.pdf
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
You should delime water heater once per year to prevent many common error codes.
http://waterheatertimer.org/pdf/Delime-tankless-water-heater.pdf
Posted on Aug 24, 2012
E9 DISPLAYED IN WASHING MACHINE DAEOO MODEL DWF320LR WHAT IS THE PROBLEM
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
Jun 01, 2017 | Washing Machines
I have a Friedrich QuietMaster Electronic SS12J30D Air Conditioner and I got an E9 error, what does it mean?
E9 is the code for heat pump failure. If you can locate your reset button, reset the unit. If it doesn't work, you might want to consider getting another unit
Aug 08, 2016 | Friedrich Heating & Cooling
Bloomberg freezer error code e9
Error Code E9 ' Appliance Video
www.appliancevideo.com/repair-help/question/error-code-e9
The unit keeps getting a low water error and everything I could think of checks out: inlet valves, w. ... Error Code E9 ' Appliance Video .... Ice on bottom of freezer
Jul 23, 2015 | Blomberg BRFB1150 | 11.7 cu. ft....
Error code E9? in godrej split 1.5 ton AC
Godrej 2 ten indoor despily e9 cood
Mar 17, 2014 | Heating & Cooling
Error code e 9
E9 indicates Voltage error. Check the power.
Feb 01, 2014 | Midea Heating & Cooling
SUNFLAME INDUCTION COOKER IS SHOWING E9 ERROR CODE AFTER HEATING
Ihave a sunflame induction cooker. Whenever i start after 2 min it shoes e9 and stop working what is the reason
Jan 26, 2013 | Cooktops
How do i fix code E9 on midea air conditioner
I have a problem with Midea Brand Aircondition .display shows E9 code error,what is a solution
Dec 22, 2012 | Midea Heating & Cooling
E9 ERROR IN HITACHI AC
HI
MY HITACHI WAC MODEL for 1.5 lr, DISPLAY SHOWING E9 ERROR CODE. ALREADY COMPLAIND TO HITACHI CUSTOMER CARE, BUT NOT GETTING POSITIVE RESPONSE. NOW CAN YOU PLESAE LET ME KNOW WHAT DOES THAT (E9) ERROR MEANS AND HOW TO RESOLVE THE SAME?.
THANKS
Jul 04, 2012 | Heating & Cooling
No heat to the dryer. Everything else seems to function properly. Frigidaire AEQ7000ES1. Receiving E9 Error code.
heatman101]][
Jul 18, 2011 | Frigidaire Electric Dryer
Got error code e9 on freidrick ac
e-9 Unit cycles(Heat or cold) 3 times per hour.Unit undersized /High load conditions.Fix higher capacity of the unit.
Jul 20, 2010 | Friedrich QuietMaster Electronic SS12J30D...
Kitchen Appliances - Others Logo
132 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
