Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
How do I restart my stove after a F9E0 code flashes?
This occurred after power outage
    Champion:
  • Whirlpool Expert
  • 220 Answers
The control thinks thinks the heating circuit is open was the oven in use when power went out possible one of the leads may have come off or burned off one of the elements I have seen outages damage a lot of controls with oven off try cancel/off, cancel/off then start to go into diagnostic press the 3 or ^ key till you get to errors follow the prompt to reset this my help
Posted on Apr 04, 2015
When we reset the clock after a power outage, the clock runs fast now almost a minute in 30 seconds. Bosch HBL5750
Advise manufacturer; may give you a warranty on this part even after it has expired because of nature of the problem.
Mar 08, 2015 | Bosch HBL5750UC Electric Oven
My Westinghouse 668 wall oven won't allow me to set the time. We had a power outage and I have checked the power and it's fine now. But the display flashes between 0:00 and auto and I can't hold the two...
Does the rest of the oven work ok? Did the timer work OK before the outage? Is the oven under warranty? Was the power outage at your home only? Check with the manual to see if it addresses your problem, there may be a way to reset the system and then I would say that you would need to contact Westinghouse and explain the situation.
Nov 06, 2014 | Ovens
Kenmore Mod.# 75824 I have a Fault Code EO-F3- the oven does not come on. No time display. I've reset the breaker and pushed the cancel/off button no help. This occured during a power outage.
Shorted sensor. Unplug the sensor and check it between each prong and the frame. If you get continuity you have a bad sensor. If the sensor is good, the wiring or the oven control is bad. The oven control has got to have a good sensor so it can know the temp inside the oven.
Jul 12, 2010 | Kenmore Ovens
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
I have a ' Firenzi ' electric oven which has ceased to function after a recent power cut. The word ' STOP ' appears on the display. Can you help? Regards Norman Dayton
HI. This will occur when a surge has entered the unit, due to the power outage. Normally, there will be a power surge when the power is re-introduced to the home circuits after a brief outage. This will damage most unprotected electronics in this situation. The most vulnerable area in the unit will be the main control board. I would advise to try a hard rest. You can initiate this by simply shutting down the appropriate circuit breaker, or unplugging the unit for 5 minutes. Once the 5 minutes have passed, kindly re- introduce power to the unit, and try to run a baking cycle. If the word stop, or PF illuminates on the display, this will confirm that the surge has damaged the board. It must be replaced, in this case.
Nov 13, 2009 | Ovens
F7 code on maytag cwb3100aab 24" wall oven.
Hi, The Function key is shorted or stuck.
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Apr 11, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
No heat from any element on any setting
first check your voltage to the unit
Dec 30, 2008 | Ovens
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Error codes
Clock error it happens when the external clock goes out of sync with the internal clock nothing to worry about it should have went away on its own after about 30 seconds
Dec 06, 2007 | KitchenAid KEBC277 Electric Double Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
793 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
