Question about Pulsar Watches
How do you open the back to change battery - Pulsar Watches
Battery change
  • Open back
  • Note battery polarity and remove
  • Install new battery
  • Close back
  • Set correct time
Jul 12, 2016 | Watches
How can I remove the back to change battery?
Yep.. unless you have a self winding one. They require a sharp jewelers tool to open.. Sometime you can do it yourself , but you chance ruining the watch with scratches. The jeweler puts the watch in a holder that protects the crown and steady the watch. He then takes a tool and inserts it in the seam of the watch back and pops the back open. After the battery is changed the back is pressed back into place by the devise that can put pressure on the back without risking cracking the crown.. Come on man it's only 8 bucks. Just remember once the back has been opened water proof can not be guaranteed anymore.
Jul 06, 2015 | Watches
How do you take the back of a wrist watch off so you can change the battery
The Proper way is with a "watch case wrench". They can be purchased for a few dollars on Amazon and E-bay. In most cases unless you are changing many watch batteries the best option is to call around to local jewelers and pawn shops and ask how much to replace a watch battery. In my town it ranges from $30 to as little as $5.99 battery included.
Dec 14, 2013 | Meco 2PCS Watch Case Back Opening Tool...
How do I open the back to change the battery on my timex e tide/temp watch
you had to have a knife caseback opener or any flat tools. look for the small opening on the back located on the upper right side of the caseback, insert the flat tool inside of it and just flip it up. then it pops out. note: after you had change the battery, you had to use pressing tools to cover it again because it cannot press by hands to seal it. it uses CR2016 size of battery. i hope i had been helped you.
Aug 20, 2011 | Timex Watches
I need to change the battery of my watch and i don't find the place for removing the back cover
some watches have a notch that comes out where you can get a knife, or exacto blade underneath to pop it open. if not, there may be multiple intends along the ridge that would require a special tool to twist open. any jewler could change the battery for you. also, batteries plus stores can change the battery out at a reasonable price.
Aug 15, 2011 | Callaway CY2058 Sport Series Watch
After changing the battery nothing can be changed, no function possible and"open" remains written on the display, the type of the battery is clt 1616
The battery is CTL 1616 and I had the same occurance when I opened up my model Casio model 3043. I needed to use the battery to test my model 2767 and find out if a new battery would bring it back to life (yes, it still lives). After replacing the battey back into my 3043, I jumped the (ac) to (-) and at first the watch would indicate all was well but then it would revert back to "open". I tried over and over to try and get the "open" display to clear but I was not successful. I then thought to go ahead and replace the back on the case to see if the three contact springs would change the display and sure enough, "open" no longer was in the display. The watch works perfectly as before. As for the 2767, as soon as I jumped the (ac) to (-) the "open" display went away. There is only one spring contact to the back case on the 2767 model. Unfortunately I do have an extra spring that fell out when I opened it up and I have no clue as to where it goes. I have not found anyone who can help me on the location for the shorter spring. Any advice would be most helpful.
May 20, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Kenneth cole reaction KC1408 changing battery problem
You have to take the back off. If it has about 6 slots around the back, then it screws off. If it's flat, then you can pry it open. If you pry it open, it,s very difficult to get it back on all the way. You may have to get some tools, or go to a repair shop.
Mar 02, 2009 | Kenneth Cole Watches
Battery....can I get a battery replacement anywhere?
Most Skagen watches have a snap-in, snap-out back. You will need a tool to open the back such as a slotted jeweler's screwdriver or knife blade to pry it open. Be careful opening the back as the battery may pop out. Examine and make note of which side of the battery is up. Get the number off the battery, or take the battery with you to Wal-Mart, Radio Shack or anywere else they sell batteries. Buy a replacement, install it, and try to reinstall the back. You may even consider taking the watch with you to the above retailers...some of them are willing and able to change the battery for you.
Dec 08, 2008 | Skagen Watches
Need to change the battery on my fossil watch but can't seem to remove the back of the watch to do so
good morning ! if your watch is waterfroop design that`s have a tread so if you want to open the case back you need a wrench or opener, but if your watch is snop in design you need a knife to open the case back,and change the battery,thank you,
Aug 27, 2008 | Fossil Watches
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Watches Logo
50 people viewed this question
Top Pulsar Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
