Question about Samsung HL67A510
I Have a pending question that has not been answered is it because I left the A off the model number ?
My name is James M. Younger the set keep turning on and off randomly. I changed the lamp and it still is doing the same.
  • James Younger
    James Younger Apr 08, 2015
    Additional infromation for my question. When I first had this problem I was streaming music with a Roku 3 from Pandora. When the TV cuts on an off there is sometimes a very faint picture and there are also a few white dots that has been on the screen for sometime. I hope this additional information helps. I do want to try to fix this TV is has a wonderful picture. Thanks for any help. James
    Master:
  • 373 Answers
Check for bad capacitors on the power supply board.
Posted on Apr 08, 2015
    Master:
  • Samsung Master
  • 688 Answers
The door switch of some of these units caused that problem. see following web site: http://www.amazon.com/AA41-0756C-Switch-Sensor-SAMSUNG-HLP4663W/dp/B00NH49Y4E
May also be the lamp itself, possibly got a bad lamp
Posted on Apr 14, 2015
Unique Boy s Name?
Leonardo.
Jan 04, 2017 | Books
Need to change my first name spelling
Open your account settings. Log in to Facebook and click the Gear icon in the top-right corner of the page. Select "Account Settings".
  • To access this on the mobile app, click the menu button in the top-left corner and scroll down to Account Settings. Select General, and then tap Name.
  • 2
    Click on your name to open the name editor. You can enter a First, Middle, and Last name, as well as an Alternate name (such as a nickname or maiden name).
    • Your name can only be changed four times.
    • Facebook wants you to list your name as it appears on your credit card or ID.
    • You cannot use symbols, numbers, random capitalization, or punctuation.
    • Your middle name cannot be words or phrases.
    • Nicknames should be variations on your real name (Jim instead of James, Meg instead of Megan, etc.)[1]
  • 3
    Enter your real name. Facebook does not allow you to impersonate someone else, or create a page for a fictional character. Accounts found in violation of this will be forced to change the name.
    • If you want to create an account for an organization, business, or a pet, you will need to create a Facebook Page.
  • 4
    Enter your password. To change your name, you will need to enter your password into the box before you are allowed to save your changes.
  • 5
    Click Save Changes. Your new name will be saved, and the change will reflect on your Profile shortly. It can take up to 24 hours for a name change to be approved
Dec 09, 2013 | Facebook Social Network
Pt50dl14 i changed the lamp turned tv on. bulb lit then shut down within seconds. now the lamp and stand by/ temp. are flashing and tv will not turn on?
If Akai brand that is Samsung (they own the name).
I have a simple suggestion-----remove the lamp with cartridge (set unplugged) and look where the lamp faces-----the color wheel this model uses fails--I will attach a photo.
What you are looking for is: are any segments missing or the wheel even shattered?
These fail often and the set if wheel (turns at over 8,000 rpm) slows down, shattered, or missing pieces the set will detect that and turn the lamp off almost instantly.
Let me know as if this is the problem it can be a do it yourself replacement as You Tube has video instructions for this on most models.
Apr 13, 2012 | Televison & Video
Where are the Bios jumper pin located on this motherboard so i can clear my password and what is the configuration settings? HP Compaq, windows xp, pentium 4, 317577-001, Ct: L6BC70C6JPC4R, S/N...
Hello James,
To clear a Bios password, you can simply take out a battery for a while, then you will get factory setting in Bios, so no password. If you have done any major changes in Bios, you probably should not try thi (I do not know how skilled you are)
Jul 05, 2011 | Computers & Internet
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
When i send an email it says from chris tejada cause thats what i wrote when i was younger how do i change that cause everything else says my real name
Login to your Yahoomail and then go to the following location:
Options -> Mail options -> Accounts -> "Your From Name"
Here you can change how your name appears when you send an email.
Cheers!
Nov 18, 2010 | Yahoo Mail
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Oct 26, 2010 | Samsung Televison & Video
My Samsung HL-P5063W set turns off on its own randomly. Set is 5 years old. This started after I went on the AT&T Uverse service, but that may be coincidental. The Uverse box and service stay on, but...
First thing change the lamp. There are several other things but this is most common. Be sure tab on lamp door presses door switch in downward position when you change the lamp. MCM Electronics you can get a philips bulb for $99.00.
Nov 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Hitachi 50VF820 (LCD projection)randomly turns off, all three lights (temp,lamp,power)blink then the set turns back on after approx. 30-45 seconds. Lamp was changed approx. 4-5 months ago. Cleaned out all...
I believe I may have solved this problem by putting a small fan blowing on the intake of the Lamp fan. I put the fan in place and the TV has not turned off randomly since. That was only a day ago so I'll see if it is a permanent fix. If so I will probably try to mount the fan on the back of the TV out of sight.
Jul 16, 2008 | Televison & Video
Samsung HL67A510 Logo
165 people viewed this question
Jerry Greenberg
Jerry Greenberg
