Power to control board but no display and machine does not operate
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check door inter lock
Posted on Apr 12, 2015
LG WM2016CW When I hit on button it chimes but control panel doesn't light and washer won't start
To determine if the user control and display board is defective, try pressing the buttons on the control panel. If some of the buttons work, but others do not work, the control and display board might need to be replaced. Additionally, if the display is not working, check the power to the user control and display board. If the user control and display board has power, but it isn't working, replace it.
The main control board may also be faulty.
Aug 07, 2015 | LG Washing Machines
My he2plus waher won'y unlock and displays code f o1
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 25, 2010 | Kenmore HE2 Plus Front Load Washer
Error code F11
F11 is an indication of a communications problem.
Communications cannot be sent correctly between the machine control board and the motor control board.
Here are some possible causes:
  • Loose wire connection at either the machine control board or motor control board.
  • Machine control board failure
  • Motor control board failure
  • Door lock
  • Motor
Error codes can be caused by a Power Surge or other electrical anomaly, attempt to return the washer to operation by following the Hard Reset procedure below.
  1. Unplug or turn the circuit breaker off for 10-20 minutes.
  2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  3. Press the Pause/Cancel/Stop button twice to clear the display.
  4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Aug 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We've a Ricoh MP3500 that is displaying an error code SC672 and directs us to switch the main power and switch back on. When switched back on, we have the same error code. Advice?
sc672 is a communication error between the controller board and some other component. Did you switch the machine off using the orange power switch on the lower left side, or just the power button on the operation panel?
With the power completely off and the machine unplugged, pull the controller board out by removing the two screws holding it in on the rear left side of the machine. (It should slide right out the side.) Check all of the connections on the board and make sure everything is sitting securely, then reinstall the controller board.
Worst case scenario, you might have a bad memory stick, bad controller board, or another bad circuit board, but more than likely there is a connector somewhere that just needs to be set securely. You can also remove the operation panel (two screws on the top of the panel and possibly two screws underneath it as well) and check the harness that connects the op panel board to the machine.
Jul 16, 2010 | Ricoh Aficio AP3800C Laser Printer
Display is showing f1
Jul 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 11 code
  • Door lock
  • Motor
Jun 17, 2010 | Kenmore HE2 Plus Front Load Washer
82822 / 82824 / 82826 Electric Dryer: kenmore HE2 electric dryer, beeps and all display ...
May 17, 2010 | Kenmore 82822 Electric Dryer
Code u9-80
This indicates a communication failure between the Main Control Unit and the operation control circuit board. Power the machine down and disconnect from hte power supply. Check all the connectors and wiring on the boards and also any loose wiring that may be grounding the machine. Power back up and if the fault persists a qualified copier engineer will be required.
Mar 10, 2010 | Sharp AR-M237 Copier
Washer displays F-01 signal. Will not drain and when cancelled cannot open door
Oct 12, 2009 | Kenmore Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
