Question about Refrigerators
Just bought yesterday 1 year old looks mint, left to stand 4 hours plugged in not cold or freezing anything all lights are on but warm inside?
  • Refrigerators Master
  • 5,323 Answers
Check ur cold control thermostat, ur thermistors, ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Posted on Apr 04, 2015
The battery died in my 95 jeep grand cherokee laredo an now it wont hold a charge
If the battery is old(2 to 2/12 years) the battery is sulfated and worn out inside. Going dead is just the nail in the coffin. Plus, a discharged battery will freeze in cold weather, allowing the ice inside to bend and break the lead plates inside, causing shorts to occur and will drain the battery after charging. If it were me, I would bring the battery somewhere warm for 8 hours, slow charge it, then have it tested. If it's more than 2 1/2 years old, I would just replace it.
Jan 31, 2017 | Jeep Cars & Trucks
GALANZ 2.7 Mini Refrigerator Model # GL27BK Brand new, won't keep anything cold , even on the highest cold setting.
Well, it's under warranty. You take it back and ask for a replacement. You have given it sufficient time to cool.
Oct 17, 2015 | Refrigerators
I do not recall the model number for my side by side fridge. We did not use the fridge for 1 1/2 to 2 years. I recently cleaned it up, plugged it in and while it runs and the outside feels cold to the...
after standing for so long it may need regassing.if you have left it running for at least 48 hours and no cooling occurs,this would be my first fix
Oct 21, 2010 | Kenmore Refrigerators
Lec elan a class under worktop freezer 4 years old.Red light has been on for 24 hours,food still appears to be frozen.What do i do
check that the thermostst is working,, if its not it wont turn on the compresor,,, and it stops freezing the red light is the warning light that tells you its getting warm inside the freezer ie:hotter that -16* it will soon start to de-frost withing 24 hours keep the door shut if you can till its been looked at,, but get it looked at very soon or you will loss every thing in there
Nov 17, 2009 | Amana ABB1927DE Bottom Freezer...
Broken plasma display panel
hi,i have same hitachi p50h401,just over a year old,mint condition never use stand but boards inside have some problems(blue light is flashing but tv not turning on).will sell it or buy yours.thx oliver.e-mail to oshvetz@yahoo.com
Aug 09, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Freezer not freezing and blowing luke cold air. Fan running full time.
rotate the defrost heater timer until it clicks and see if the defrost heater is working
Jun 02, 2009 | Refrigerators
Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
i find it hard to believe the compressor is going out,if the fridge is staying cold,put a thermometor in the fridge and it should stay about 32 degrees,ideally around 40 is a good temp.if the freezer isnt staying below 32 degrees then it sure sounds like a thermostat problem.But i have heard of computers in these newer refridgerators but havent worked on any just yet.
May 09, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
How cold is too cold for the S730?
Take the camera inside and let it warm up to room temperature. Get another set of brand new batteries. But first take out the batteries and let it sit for an hour. Without any power it can reset itself. The mini cpu inside is thinking its too cold and won't let it come on. After the one hour of sitting, put the new batteries in it and try to power it up. Cold weather can kill a brand new set of batteries in a matter of minutes. You should try not using your camera when its below freezing.
Jan 09, 2009 | Samsung Digimax S730 Digital Camera
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
