Question about Harman Kardon AVR 85
When i turn it on i get text in disply "protect" what can i do?
Sir my MHC-RV900D is disply shows push power protection again and again.plz solve my problem. thank u
There is most likely a short in the amplifier that will need to be repaired before the unit will power on normally.
Mar 12, 2013 | Sony MHC-GX40 CD Shelf System
It's did not take memary card. it's sey's format the memary. I reformat memary but same problem and after chenge new memary displyed same problem. it's can fix??
The 4GB card is an SDHC card and will not work in the 735. The 2GB card should format in the camera. Make sure it's not write-protected. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 28, 2012 | HP Photosmart 735 Digital Camera
I put text on my photos when i try to save them it say," may be write protected. How do i disable it.
There is a tab on the SD Card that you have to slide that turns the write protect on or off.
Here's a link to Youtube Video that shows you. Just click the link below.
http://www.youtube.com/watch?v=a_XkvkHDveo
Apr 27, 2012 | Dell Inspiron 530s Desktop Computer
Disply said "proctected"
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure
the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without
addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 15, 2011 | JVC HX-D7 Shelf System
My 5130 mobile disply damaged now its displying vertical and reversible letter displying what i do my mobile warrenty is over
when i turn on my fone, the screen remains blank but i am still able to press buttons into it. can you help?
Oct 03, 2010 | Nokia 5130 Cellular Phone
Won't send messages
disply show is dead tell me and mail me sameer_mishra1@yahoo.com
Aug 25, 2009 | Samsung Gravity SGH-T459 Cell Phone
Black Screen on Razr V3
at first try changing Software of your cell. If the problem not fixed, check disply IC,Connector and finally the disply
Dec 15, 2008 | Motorola Mobility RAZR V3
Deleting text messages
you mean the c168? the center key > Messaging > Message Inbox
> highlight message > SELECT> OPTIONS > Erase
Dec 10, 2007 | Motorola Mobility V551
Harman Kardon AVR 85 Logo
49 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
