Question about Dishwashers
Seems like machine does not get water although water is available.When you turn on machine you hear something but no water I think
    Champion:
  • 208 Answers
You could try taking off the hoses and checking if there is a screen blocked in the inlet...
Posted on Apr 04, 2015
  • 473 Answers
If after 3 to 5 minutes of starting the cycle you don't have water in the dishwasher bottom you have a problem with the fill cycle. Usually the inlet valve is bad. It is the plastic part with 2 wires going to it that the house water line hooks up to. Make sure someone didn't accidentally
turn off the house water valve to the dishwasher,
Dial won't set
you can possibly remove the knob itself, and see if you can turn the dial itself. if you can, then you can probably see the knob is broken. if if the shaft turns, but doesn't move the gears, then you will just need a new dial switch.
Nov 19, 2013 | GE Profile WPRE6100G Top Load Washer
Load size dial on washer spins freely instead of moving to setting
That setting has to do with how much water is let into the drum. You can get a new switch for that. If you post the model number.
Nov 18, 2013 | GE Profile WPRE6100G Top Load Washer
Neff S4340 integrated dishwasher seems stuck on cycle
yes take it apart under sink where it drains could be gunk in there
Feb 17, 2009 | Dishwashers
Bosch Dishwasher will not take in water
Either the pressure is too low, or turned off by accident. Otherwise it could be a faulty inlet valve
Please leave feedback
Thanks
Rob
Feb 13, 2009 | Bosch (1619EVS-RT)
Heat gauge shows hot , have to add antifreeze although no leak
Very common fault is head gaskets.  causing coolant consumption and bubbles in radiator.  Run vehicle, have a friend accelerate once or twice hard, while you smell exhaust for sweet smell of burning coolant.
Dec 18, 2008 | 1997 Ford Taurus
Won't turn on...hear the beep, and screen works.
Exact same problem for me on the exact same day (2-sep) as well - freaky! Unit was out of battery and I charged it but that was the last time I managed to get it working - charging it now to see if it makes any diff. Actually with mine I hear the beep and the initial splash screen shows for about 1 sec and then that's it - it seems to go off again. I think it's something to do with the battery as it seems to work when connected to the charger - not a whole lot of good to me!
Aug 28, 2008 | Garmin Forerunner 305 GPS Receiver
Indesit WD11
is the drum turning round. is it draining at end cycle ? if the motor is spinning is it slow at start turning left then right after a time or does it just spin when its on spin cycle ? can you hear a clicking sound when it about to move or hear a clicking sound and nothing moves ? if you hear a clicking but nothing is moving it could be the switch on the main board has worn out, it could even be the motor but if it does a spin it could just be the switch on the main board. they soldered in on the board you can replace them if you have soldering skills or would like to learn.
Jun 22, 2017 | Indesit W 123 Front Load Washer
Water Too Hot, Coffee Too Watery
Sounds like there is something wrong with the machine. Could be the thermostats or maybe something like an internal leak that is causing the machine to overheat. It sounds to me like you need someone to take a look at it..
We service saeco espresso machine and are stationed out of New York..
If you need parts of cleaning supplies check out our website:
www.CeriniCoffee.com
Jan 01, 2008 | Saeco Classico Espresso Machine
Dishwashers Logo
188 people viewed this question
Top Dishwashers Experts
