Question about Samsung Washing Machines
My Samsung washer is throwing a code looks like a BE code how do I reset it. All I do is turn on the washer and in 20 second the code comes up with out touching anything
    Scholar:
  • 189 Answers
You can try plugging the washer from the outlet. Turn on the power knob on the washer for a couple seconds to release any stored power, then turn power knob off. Plug washer back in the wall outlet to see if this resets the code back to normal.
Posted on Apr 03, 2015
  • Ivan Serrano
    Ivan Serrano Apr 03, 2015
    That didn't work any more suggestions please help
Tip
CONTROL LOCKED on Whirlpool/Kenmore Washers/Dryers
The Whirlpool duet washer needs a reset to resolve the control lock problem. To reset the washer you have to Press and hold the END OF CYCLE/CYCLE SIGNAL button for 20 seconds. This button is usually located on the right side of the panel facing the front of the washer.
Similarly, if it is a Kenmore Washer you can press and hold the DRAIN/SPIN button for 20 seconds.
To reset the Kenmore Dryer for this Control Lock problem you have to Press and Hold the AUTO DRY LEVEL button for 20 seconds to unlock the Controls.
Kevin
on Mar 06, 2011 | Washing Machines
I start the engine,then engine rpm suddenly run very high and suddenly engine just turn off. What is wrong with that..?
Have you by chance recently had any work done on your car - like a new fuel pump, relays, etc.? This sounds like it may be a fuel pressure regulator issue or something along those lines. First thing to do - if you can either get it to a parts store that will read code or you can go to Advance Auto - for around $30 you can get a hand held code reader. Basic/multi-language - not all the bells and whistles - but you don't need all the extras just to read code.
If you get a code reader or someone you know has one - turn the key to the on position so the dash lights up - but don't turn the car on. Under the steering wheel you'll see a male plug that matches the female end on the code reader. Plug it up and give it a second. If it doesn't work or gives no codes, turn key off, wait 10 seconds turn it back on and reattach the code reader. If your vehicle is throwing out any codes - they'll come up.
You'll want to erase the codes once you've written them down. And definitely retest. The codes are usually listed in order of event - but if you do not erase the trouble code, the next time you scan it'll still be there throwing off whomever is trying to pinpoint the problem.
If you plug up, choose the erase function, allow the OBDII to reset, then try starting the vehicle, etc. and retest. Since you erased all previous codes - the only ones you'll see now are current.
Actron PocketScan Code Reader Coupons for 20 30 Discount Mighty Auto Shop
May 05, 2016 | Cars & Trucks
I have to turn power switch off then back on on my minimax NT , then service light will flash once blower comes on for 20 sec. then shuts off i have nothing. What part should i throw at it first
Any fault codes?
what about the flashing Red light?
how many times is it flashing quickly? It will pause between message/code of quick blinks.
To assist, more info needed.
Jun 02, 2015 | Pentair Minimax NT Heater
I have a Samsung RF268ABRS Unit all food in bottom freezer thawed. Unit is running and ref is cool. I notice that the fan dosent seem to blow. Closed freezer up and its cold, but no air moving. How do...
I had a similar problem. my samsung freezer would only cool to 20 degrees, which also resulted in the freezer ice maker not functioning. (fridge door ice maker still worked) If you hold the power freeze and power cool buttons down together for 8 seconds it will a diagnostic. found the answers on http://appliancejunk.com/forums/index.php?topic=8206.0 , as too what the codes meant. Mine was throwing a freezer fan code error. ordered one online $30 and replaced it. seems to be working. TIP -The fan is located behing the rear panel in the freezer. I had two fans. The regular looking one is the freezer fan, the squirrel cage fan feeds the fridge ice maker. Also the new fan motors don't come with blades, just pull the blades off the old one and put it on the new motor. Don't push it on too far, make sure there is enough clearance so it spins freely.
Jun 28, 2011 | Samsung RF267AB (25.5 cu. ft.)...
Quiet pak 4 shows code 20 it will fill up and wash 2 minutes before it throws a code
"F20" error code is indicating that no water is detected entering the machine or the pressure switch trip is not detected. If after 30 seconds of filling with water and the minimum of 0.11 of water is not detected entering or the maximum fill time of 16 minutes is exceeded, the valves will turn off and the error code will be displayed. It is an indication that you either have no water coming into the washer, or very little water at all. If you have verified the water pressure is fine, you may have a faulty Flow Meter. You could remove the cold and hot water supply lines, after shutting the water off of course, at the washer and then look to see if the filter screen is restricted inside the water inlet valve on the washer.
The first would be to blow through the pressure switch hose towards the tub. You should be able to blow through the hose without much force. If the air trap the hose is hooked up to is blocked then the pressure switch will not see the water entering the tub. With the tub empty blow through the hose and then hook it back up and see if there is any improvement.
Mar 12, 2011 | Kenmore Washing Machines
Samsung front loading washer temperature sensor problem
It may not be your temperature sensor or thermistor. If you have a tE error code on your Samsung washing machine, first check the wiring. My Samsung washer had three visits by the repair tech. and new parts ordered again and again. I looked on a British web site and two people said that it turned out to be wiring broken in several places. Sure enough, I found a broken wire. Technician didn't look for that. Hope it's as easy for you.
Feb 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Unlock code
The code is *2767*2878# with no card installed
This is a custom reset to factory default setting
This code is to enable to use your phone if it was locked
To unlock your phone to make it sim free ( any sim card can be use )
There is 2 codes that is necessary
Only 2 codes, do not do a full reset
Installed a non t-mobile sim card
The disply will shown WRONG CARD
Enter *7465625*638*00000000*00000000#
The 00000000 will shown as - - - - - - - -
There are 2 set of 8 zeros
Wait 20 seconds
The next entry will not shown on the display, enter with care
Enter #7465625*638*00000000#
Wait 20 seconds
Turn phone off
Pause
Turn phone on
Enter *#7465625# to check the phone lock status
All locks should be inactive
If NETWORK lock is still active
Feb 01, 2008 | Samsung SGH-t219 Cellular Phone
Washing Machines Logo
139 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
