Question about Cameras
I think I reversed polarity and now my charger won't work. How can I fix this?
    Top Expert:
  • Cameras Master
  • 51,191 Answers
OOPS usually when a person does that it's time to bite the bullet and buy a new unit
Posted on Apr 04, 2015
    Top Expert:
  • Cameras Master
  • 6,702 Answers
Not sure what you wanted to charge, but with reversed polarity most of the time the device connected, will be "dead". It could be you destroyed the battery(s) When that is all, a new battery(s) should solve the problem. Only when the reversion, caused a shortage, that could have blown a fuse. When you connected a camera or another device, it could be that or the internal battery is defect.
Lead acid Car battery was charged with polarity reversed. Can it be re-charged correctly? It blows the charger fuses??
a lead acid will not charge with the polarity reversed
What happens is that in dead shorts and can destroy the battery
it can blow up the battery , blow the charger fuses and destroy the charger
Depending on the damage to the battery cell plates it may be recoverable
Mar 30, 2018 | Cars & Trucks
What damage did I do when reverse polarity jump started?
Try another battery and see if that sorts it. Otherwise something may have been fried.
Aug 08, 2014 | 2005 Harley Davidson FLHR - FLHRI Road...
I have a 2005 magnum front passenger window won't come down all other windows work properly I replaced the motor and it rolled up and stayed there won't come down I Cleand the connection nothi
Did you try direct 12vdc power to motor wires ? Reverse polarity should change direction of motor, then you'll know it's switch related or whatever. Did old motor do same? The switch reverses polarity, or is supposed to. If a motor goes in one direction, when wired backward ( reverse polarity) it should go opposite direction. That tells you motor is fine.
Jan 24, 2013 | 2005 Dodge Magnum SXT
Honda eu10i reverses polarity on boat
Polarity lights in AC means that it thinks the wrong input lead is earthed ie neutral.
If polarity detector is showing that there is no neutral earth bond it may not be a bug but a feature, as standard the EU10i would not have an earth neutral bond.
Otherwise I can not see why your detector thinks there is a polarity reversal.
Kevin H
Jan 24, 2013 | Honda Eu-1000i Inverter Generator
What is the polarity of a 12v Black & Decker Drill?
centre pin on plug socket is usually positive...
think I would **** it and see ....if the replacement charger has a charge light it will probably not light if you have reversed polarity. Had the same problem with VHF portables ...I just cut the wire on new charger and tried both options ..reconnected and a bit of tape...voila.
There is little danger to your drill from getting it wrong as long as a the timing is relatively short.
May 29, 2012 | Black & Decker Drills
How do i fix reversed 115 polarity on a heat unit amana
Can you be more specific with your question? A 230V unit won't work with 115V power. Reversed polarity may just mean that the outlet is wired backwards and the wires need to be switched around.
Nov 01, 2011 | Amana PTH153B25AJ Heat Pump Air...
I need a power cord for this phone and i plugged in another power cord to see if it would work and it popped and some smoke came out of the hole where the charger plugs into , do you think i could have...
Yes, the polarity of the charger you used was probably wrong for the phone. The power circuit is probably fried. It would cost nearly as much to fix that as it would be to get a new phone.
Always make sure to check charge polarity and voltage before plugging chargers into just any devices. Some will work, but as you found in this case, some don't and can do substantial damage.
Chris
Sep 23, 2011 | Office Equipment & Supplies
I cant get my power chair jet 3 to charge batteries are good
Hi valentin 201
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. . In the future give as much info about the scooter as possible.
1. load test the batteries even if you think they are good, check anyway. Sometimes even new batteries won't hold a charge.
2. Your charger on the powerchair must have enough volts to open the charger inhibitor. That is, the charger won't even start up if your batteries are low. Both batteries need to have at least 20-22 vdc.
3. Some chargers have a 3amp fuse check that and repace if needed.
4. With a multi meter set on dc200 check your batteries. Red on one battery and black on the other. Check to see what you get for voltage. If no voltage reverse the lead wire to the other posts. Once you get a reading of 20+ volts watch the meter and plug in the charger, it should increase the volts on the meter. if not the charger is bad, replace. Charger should be 24-31 volts to be a good charger.)
One of these sugestions will fix the problem
Good Luck
Tim
May 03, 2011 | Jet 3 Ultra Power Chair
A quick question, I have an Acer Aspire 5516 and today the charger just flat out stopped working. it was a 19v 65w charger, then I had gotten a universal charger that came with 19v 75w and 19v 90w tips. I...
You do not have to be worried about the wattage. Wattage (in the case of chargers) is the capacity a charger can provide. So higer the wattage better it is. However, higher the wattage higher the price usually. Voltage has to match. But the most important thing to look for when you buy a universal adapter is the polarity. Take care to match the polarity. Polarity will be represented by a small line encircled by a circle with + AND - . If you look at it carefully you will understand that it is trying to tell you what polarity is the inner lead and the outer lead. You will see this marking on the charger and also on your laptop close to the DC in. (Usually the inside lead is positive and the outside lead is negative) However some manufacturers reverse this. (I have no idea why they do it though I think some kind of regulatory body should make a standard to avoid unsuspecting users from frying their devices). If your voltage and polarity is matching you are good to go with 65 watts or above. If this holds good, don't worry about any listings.
Sep 19, 2010 | Acer Computers & Internet
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
